Help with IFTTT and Blynk
Hmmm, you mean like this?
Not directly within Google Home or IFTTT, but you can do it in code.
Here’s an example (although I’m NOT advocating the use of delay() within this function, you should probably use a non-blocking lambda timer instead).
