Hi all,
Im using an ESP32 and trying to make a heater thermostat that checks the temperature, sends an RF signal to turn on and off the heater. I
m stuck with what I thought would be a super simple part! I`m using Blynk which is new to me and whilst playing with arduino for years, I only just get by so probably something simple!
I`ve put all my code below which individually all works. The RF signal can be sent, the temperature is being read OK. I have an overall ON OFF button in blynk which is a switch in the app that writes to Virtual Pin 2.
The issue is this: I`ve got a global variable called “HeaterFlag” which I define right at the start of the code.
I use Blynk_write on V2 which flips a variable called HeaterFlag - it turns off and on an LED and also writes the value of HeaterFlag 1 and 0. This ALWAYS works. When I press the button in blynk, the LED correctly switches and the HeaterFlag correctly shows 0 or 1. However the error below occurs when I put the IF statement in the main loop, then the LED still comes on and off but HeaterFlag is constantly 0.
BLYNK_WRITE(V2) {
// any code you place here will execute when the virtual pin value changes
HeaterFlag=!HeaterFlag;
ledState=!ledState;
digitalWrite(LED, ledState);
Serial.print("HeaterFlag: ");
Serial.println(HeaterFlag);
In my main loop Ive got an IF statement which uses HeaterFlag. I
m basically trying to say if HeaterFlag is on, I want the code in the loop to run and send an RF signal. When I boot up the board the HeaterFlag is 0 but then immediately changes to 1 and the loop code ALWAYS runs! It is driving me crazy and cant see why. However what is mad is that when I press the button I still get HeaterFlag 0 and it won
t change and yet the LED is doing what it should do. It is like the HeaterFlag is not being set as a global variable and the heaterflag is just doing its own thing in the main code!
Can anyone explain why.
Ive also snipped some of the serial monitor as well to show you. The single "HeaterFlag" lines are just coming from the BlynkWrite function when I hit the button in the app but as you can see it isn
t setting it as a global variable! When I remove the “If Statement” in the main loop, the heater flag sets properly but then Im obviously not using the IF and my code isn
t doing what is should.
Thanks in advance!
SERIAL MONITOR:
Set temperature:35 Min temperature:15 Room temperature:15.75 HeaterFlag:1
HeaterFlag: 0
HeaterFlag: 0
HeaterFlag: 0
Full code.
#define BLYNK_TEMPLATE_ID "TMPL5aPhEfQeM"
#define BLYNK_TEMPLATE_NAME "20B18 Temp Semsor"
#define APP_DEBUG //#define BLYNK_DEBUG
#define ONE_WIRE_BUS 4 // Your ESP8266 pin (ESP8266 GPIO 2 = WeMos D1 Mini pin D4)
#define LED 2 //this is the onboard LED for testing
#include "BlynkEdgent.h"
#include <OneWire.h>
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch(); //switches the heater on and off
char ssid[] = "I`ve removed this because its personal info;
char pass[] = I`ve removed this
char auth[] = I`ve removed this
float roomTemperature; // Room temperature in F
bool HeaterFlag = false; // if this is ON, the thermostat will work, if not, the transmitter is not running
bool ledState = false; //initiate the LED as off
//delay without delay setup
unsigned long heaterInterval = 3000;
//setup of the RF TX
int transmitterValue; //somewhere to put the on/off code
int txOFF = 001111101010110101010100; //off signal for TX
int txON = 001111101010110101011000; //on signal for TX
int tempRange = 20; // THIS IS THE BUFFER/RANGE BETWEEN HIGH AND LOW/ON AND OFF
int setTemp = 35; // THIS IS THE SET TEMPERATURE
int lowTemp = setTemp - tempRange;
// setup Transmitter info
mySwitch.enableTransmit(12); // Transmitter is connected to Pin #12
mySwitch.setPulseLength(415); // Transmitter pulse length.
// mySwitch.setProtocol(2);// set protocol (default is 1, will work for most outlets)
mySwitch.setRepeatTransmit(15); // repetitions of transmissions to ensure transmit.
Serial.begin(9600); // Debug console
Blynk.syncVirtual(V2);
sensors.begin(); // Starts the DS18B20 sensor(s).
sensors.setResolution(10); // More on resolution: http://www.homautomation.org/2015/11/17/ds18b20-how-to-change-resolution-9101112-bits/
pinMode(LED, OUTPUT); //setup the test LED
timer.setInterval(2000L, sendTemps); //sets the temp sending frequency 2s
//Read TemperatureFunction
void sendTemps() {
sensors.requestTemperatures(); // Polls the sensors.
roomTemperature = sensors.getTempCByIndex(0); // Stores temperature. Change to getTempCByIndex(0) for celcius.
Blynk.virtualWrite(1, roomTemperature); // Send temperature to Blynk app virtual pin 1.
//This is the function which turns on and off the thermostat function.
BLYNK_WRITE(V2) {
ledState=!ledState;
if (HeaterFlag = true) { //ONLY RUN IF THE HEATERFLAG IS TURNED ON
unsigned long currentMillis = millis();
if (currentMillis - previousMillis > heaterInterval) {
Serial.print("Set temperature:");
Serial.print(setTemp);
Serial.print(" Min temperature:");
Serial.print(lowTemp);
Serial.print(" Room temperature:");
Serial.print(roomTemperature);
Serial.print(" HeaterFlag:");
if (roomTemperature > setTemp) { //if the temp reading is higher than the set temp, turn off the heater
mySwitch.send("001111101010110101010100");
Serial.println("OFF SIGNAL SENT");
if (roomTemperature < lowTemp) { //if the temp reading is lower than the low temp buffer reading, turn the heater on.
mySwitch.send("001111101010110101011000");
Serial.println("ON SIGNAL SENT");
