I am a complete beginner when it comes to Arduino, NodeMCU and Programming in general. I am trying to learn by doing some basic projects, whilst connecting and visualising via Blynk.
I am currently trying to view the data taken from a rain sensor via the NodeMCU (A0) and display it in Blynk. I have set up my Blynk cloud but have an issue when verifying the current code I have. The error code I received can be seen below along with the code I have created so far. Any help would be much appreciated.
Arduino: 1.8.15 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Edgent_ESP8266:20:12: error: redefinition of 'BlynkTimer timer'
20 | BlynkTimer timer;
In file included from C:\Users\Conor\AppData\Local\Temp\arduino_modified_sketch_386518\Edgent_ESP8266.ino:18:
C:\Users\Conor\AppData\Local\Temp\arduino_modified_sketch_386518\BlynkEdgent.h:113:12: note: 'BlynkTimer timer' previously declared here
113 | BlynkTimer timer;
Multiple libraries were found for "BlynkSimpleEsp8266_SSL.h"
Used: C:\Users\Conor\Documents\Arduino\libraries\blynk-library-master
Not used: C:\Users\Conor\Documents\Arduino\libraries\Blynk
exit status 1
#define BLYNK_TEMPLATE_ID "XXXXXXXX"
#define BLYNK_DEVICE_NAME "XXXXXX"
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_SPARKFUN_BLYNK_BOARD
#define USE_NODE_MCU_BOARD
//#define USE_WITTY_CLOUD_BOARD
#include "BlynkEdgent.h"
void myTimerEvent()
delay(100);
BlynkEdgent.begin();
BlynkEdgent.run();
