I am currently using a Wemos D1 Mini which has been working well. It stays connected and syncs on connect perfectly. The problem is that for safety reasons I need to shut off certain pins if there is ever a loss in connection. The code below should perform this on pin 2 easily but it does not work and I am stumped. The serial monitor accurately displays connection status but the pin never goes low. Does anyone know what is going on?
bool Connected2Blynk = false;
char auth[] = "xxxxxx";
char ssid[] = "xxxxxx";
char pass[] = "xxxxxx";
const int ledPin = 2;
int ledState = LOW;
BLYNK_CONNECTED() {
Blynk.syncVirtual(V2);
BLYNK_WRITE(V2) {
ledState = param.asInt();
digitalWrite(ledPin, ledState);
pinMode(ledPin, OUTPUT);
timer.setInterval(2000L, CheckConnection);
void CheckConnection(){
Connected2Blynk = Blynk.connected();
if(!Connected2Blynk){
Serial.println("Not connected to Blynk server");
digitalWrite(2, 0); //Why does this not work? Tried ledPin, LOW. LED stays on.
else{
Serial.println("Connected to Blynk server");
