Before creating the topic
wrote a code to monitor solar and battery power using voltage & current sensors. the power levels would automatically control 3 relays basen on set thresholds. I want to monitor the solar and battery power on blynk but I dont know how to go about it.
define BLYNK_PRINT Serial
#include <ESP8266_Lib.h>
char pass[] = "YourPassword";
#define EspSerial Serial1
//#include <SoftwareSerialh>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 38400
ESP8266 wifi(&EspSerial);
int value = 0;
int adcValue = 0;
int sensitivity = 66;
int offsetVoltage = 2500;
double adcVoltage = 0;
double currentValue = 0;
double power_solar = 0;
double power_battery = 0;
int analogV = A4;
int analogI = A3;
int analogV_1 = A5;
int analogI_1 = A2;
float iout = 0.0;
float iin = 0.0;
float vout = 0.0;
float vin = 0.0;
float R1 = 10000.0; // resistance of R1 (100K) -see text!
float R2 = 3300.0; // resistance of R2 (10K) - see text!
float R3 = 10000.0; // resistance of R1 (100K) -see text!
float R4 = 4700.0; // resistance of R2 (10K) - see text!
int relay_pump1 = 3; // relay 1 connected to Arduino pin 3 and working for pumps 1 and 4 connected in series.
int relay_pump2 = 5; // relay 2 connected to Arduino pin 5
int relay_pump3 = 6; // relay 3 connected to Arduino pin 6
const int trigPin = 9;
const int echoPin = 10;
// defines variables
long duration;
int distance;
// Set ESP8266 baud rate
Serial.begin(9600); // Starts the serial communication
pinMode(analogV, INPUT );
pinMode(analogI, INPUT );
pinMode(analogV_1, INPUT );
pinMode(analogI_1, INPUT );
// relay/pump setup (declaring them as output devices)
pinMode(relay_pump1, OUTPUT);
pinMode(relay_pump2, OUTPUT);
pinMode(relay_pump3, OUTPUT);
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
void sensor(){
//This sedtions deals of voltage sensor of solar
value = analogRead(A0);
vout = (value * 4.96) / 1023.0; // see text
vin = vout / (R2/(R1+R2)); // Applying voltage divider rule
// This section deals with the current sensor of solar
adcValue=analogRead(A1);
adcVoltage = (adcValue / 1023.0) * 5000;// read the value at analog input
currentValue = ((adcVoltage - offsetVoltage) / sensitivity);
power_solar = ( vin * currentValue); // For the power coming from the solar panel
if (vin<0.09) { vin=0.0; } //statement to quash undesired reading !
// This section deals with battery voltage sensor
value = analogRead(A2);
vin = vout / (R3/(R3+R4)); // Applying voltage divider rule
//This section deals with battery current voltage
adcValue=analogRead(A3);
power_battery = ( vin * currentValue); // For the power coming from the solar panel
Serial.print("Output V = ");
Serial.println(vin);
Serial.print("Current A = ");
Serial.println(currentValue);
Serial.print("solar power W = ");
Serial.println(power_solar);
Serial.print("Battery power W = ");
Serial.println(power_battery);
Serial.print(" ");
Serial.println();
Blynk.virtualWrite(V4, power_solar);
Blynk.virtualWrite(V5, power_battery);
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(2000);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(1000);
// Reads the echoPin, returns the sound wave travel time in microseconds
// Calculating the distance
distance= duration*0.034/2;
// Prints the distance on the Serial Monitor
Serial.print("Distance: ");
Serial.println(distance);
Blynk.virtualWrite(V6, distance);
delay(5000);
if(power_solar >= 70 && power_battery >= 14.0 && distance <= 5 ) {
digitalWrite (3, HIGH);
digitalWrite (5, HIGH);
else if(power_solar >= 60 && power_solar < 70 && power_battery >= 5.8 && power_battery < 14 && distance <= 75 && distance > 5 ) {
digitalWrite (5, LOW);
else if(power_solar >= 32 && power_solar < 60 && power_battery >= 1.4 && power_battery < 5 && distance <= 150 && distance > 75 ) {
else{
digitalWrite (3, LOW);
