I m trying to install Blynk Server in a RPI 3 but I can´t access to server. I installed folowing the guide,
Install Java 8
install .jar server software
launch Blynk Server, and say started with exit
I set up static ip, I can access to internet from Raspberry I set up forwarding ip and port to RPI in my router, but I cant access to RPI from internet, i cant access to RPI from LAN. I did ping against RPI with exit from local network.
I verified that Blynk ports are open
Someone knows what occurs, wich could be de trouble???
I would start with trying to fix the LAN connection and then move on from there.
Did you make the appropriate sketch changes as well as the app changes?
Can we see your sketch?
