Help please, Is it possible to change the Authentication Token?
I have one ESP32 board installed on the roof of my house and is not accessable in this moment.
I’ve made some modifications and uploaded the new Sketch OTA not by Blynk.Air but using the Arduino OTA Library and one button from Blynk to activate the loop of OTA.
This system works since many years.
By mistake I put an Auth Token created last days for Blynk2 IoT and the baord obviously cann’t connect because the Token is not valid and device attached to that Token has been deleted , and I cann’t connect to the board to recover or upload with the correct Token…
The question is:
If I have a valid Token can I change it from the console to match the wrong one running on the board in such a way that the board can connect (It is in continuos loop looking for valid Token and connection).
In the past versions of Blynk IoT from the console it was possible to change the Auto Token but now it there only under device Info only Read…
Any help will be higly appreciated to find a solution and get my board back online…
May I ask you why you’re not using blynk edgent instead of arduino OTA ?
Because the board still with Blynk Legacy…
Blynk legacy will be retired at some point, so I highly recommend moving to the new blynk instead.
Yeh, thats why these days I’ve switched to Blynk IoT with Plus Plan on my home baord and I was trying to switch also on that one on the Roof… Blynk IoT now is very nice and more professional…
Is there any hope to recover the Auth Token from the Console?
I don’t think you can.
@bek hello. Please send me an email to dmitriy@blynk.cc I can manually do that. However, I can do that only if your email corresponds to the blynk account emails. Otherwise, I can’t know you’re the same person :slight_smile: .
That’s a permission for that (only for super admins):
Great, thanks a lot Dmitriy I will email you right now…
Hi Dmitiy, email sent with Token… Kindly let me know if there still any hope to make the wrong Token active…
Regards
@bek I got your email. But, looks like I get you wrong. You want to change the token in Blynk 1.0?
No, both Token are for Blynk 2.
One is actually running on the board but the loop is blocked in the blynk.begin auth since it was for a deleted device created from the console Blynk 2.
This one if we can activate it , the loop will unblock and the begin.blynk wil works and connect…Just activate it with Blynk 2.
In the mail I sent you the wrong one to be activated, and the working active one to be modified and replaced by the wrong one… like this the wrong one becomes active…
Sorry for the confusion:-)
