Hey guys, im new here and i really need your help in my college project. for now i just try to learn how to work with blynk and light up a led.
im trying to connect esp32 to blynk app and i get “Invalid auth token” in the Monitor.
this is what i get in the monitor:
Connecting to Dvir
....E (4582) wifi:Association refused temporarily, comeback time 649 mSec
......WiFi connected
[5157] Connecting to Dvir
[7670] Connected to WiFi
[7670] IP: 192.168.1.125
[7670]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v1.0.1 on ESP32
[7680] Connecting to blynk.cloud:80
[8542] Invalid auth token
and this is my code:
int pin = 21;
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char auth[] = "FE__ssOnWS84G2keAUvqSfTBAa5yEp7O";
char ssid[] = "Dvir";
char pass[] = "dvir5558";
pinMode(pin, OUTPUT);
pinMode(pin, HIGH);
Serial.println(ssid);
WiFi.begin(ssid, pass);
int wifi_ctr = 0;
delay(500);
Serial.print(".");
Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
void loop(){
@vatavo please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
It’s also good practice to use triple backticks around your serial monitor output - it makes it much easier to read.
thank you all really thank you, i was troubled for days.
now that everything in order can you please direct me for a good library codes for esp32 and servo motors please.
also does esp32-cam work with blynk??
i tried to download the new blynk app. and the first thing is - add new device(wifi), and then it say power on you device and make sure that indicator is blinking.
how i connect the esp32 to the new app?? how can i make it “blinking”?
