Help on Bridge 2 PIR 1 Relay
Hi everybody,
I’m trying to set up a solution to automatically swich ON/OFF lights on my house stair.
The environment have to work in booth direction: if someone goes into a PIR he trigger a relay and light will be turned ON. After some time light came back to OFF.
Hardware:
2 NODEMCU
Master NODEMCU have a
PIR (it’a a micropir to be 100% ok with 3.3v - Micro PIR Motion Detection Sensor AM312)
a relay that thave to swich on ON/OFF 220V light.
SLAVE NODEMCU have a
In terms of software the Slave NODE MCU is connected via BRIDGE to the master that trigger the relay.
In terms of harware everythinks loooks good but there is some bug in the MASTER that result in:
  • if slave is triggered everythink is fine
  • if master is triggered it doesn’t working
Here the code:
Is anybody can help me?
SLAVE CODE:
 * MODULO  PIR ONLY (SLAVE)
 * 1 LED
 * 1 PIR
 * AppName:MODULO PIRONLY - XXXX
char auth[] = "X";
char ssid[] = "Y";
char pass[] = "Z";
#define ledPin 12   //D6 LED
#define pirPin 14   //D5 PIR
int pirState;
int val;
int x;  // V0
WidgetBridge bridge1(V1);
BLYNK_CONNECTED() {
  // Place the AuthToken of the second hardware here
  bridge1.setAuthToken("X1");
BLYNK_WRITE(V0){
 x = param.asInt();
void PIRval(){
val = digitalRead(pirPin);
    if (val == HIGH) {
      digitalWrite(ledPin, HIGH);
      bridge1.digitalWrite(D5, HIGH);
      //bridge1.virtualWrite(V0, 1000);
      else {
        digitalWrite(ledPin, LOW);
        bridge1.digitalWrite(D5, LOW);
        //bridge1.virtualWrite(V0, LOW);
void setup(){
  Blynk.begin (auth, ssid, pass);
  pinMode(ledPin, OUTPUT);
  pinMode(pirPin, INPUT);
  timer.setInterval(1000L, PIRval);
void loop(){
MASTER CODE:
 * MODULO CON RELE' INTEGRATO
 * 1 RELE
 * 1 LED
 * 1 PIR
 * AppName:MODULO RELE - ce1882f6b6bf41c396e64beff822f48a
char auth[] = "X";
char ssid[] = "Y";
char pass[] = "Z";
#define relePin D0  //D0 RELAY
int pirState;
int val;
int x;  // V0
BLYNK_CONNECTED() {
      Blynk.syncVirtual(V0);
BLYNK_WRITE(V0){
 x = param.asInt();
void PIRval(){
    if (val == HIGH) {
      digitalWrite(relePin, HIGH);
      else {
        digitalWrite(relePin, LOW);
void setup(){
  pinMode(relePin, OUTPUT);
void loop(){
Partial code doesn’t tell the whole story.
Hi Gunner,
sorry you are right… somethink was missed in copy/past. To avoid confusion I edited the above message. Now code is complete.
You are also using a mixture of the silkscreened Dx pin designation and Arduino pin designations… best to use all one or the other and preferably the Arduino one (although commenting the relevant Dx pin is a good reference).
Since your Slave is triggering the Master pins directly, then I suspect something in your Master code as the culprit… possibly the aforementioned pin designations?
Hi Gunner,
I just moved all the PIN mode in the Arduino one.
Please also get the configuration in terms of wiring.
WIRING MASTER - PIN ON NODE
D5–> signal for PIR on master nodemcu
D6 --> signal for LED on master nodemcu
D7 --> signal for RELE on master nodemcu
CODING ON MASTER:
 * 1 RELE
 * 1 LED
 * 1 PIR
 * AppName:MODULO RELE - XXXX
char auth[] = "XXXX";
char ssid[] = "YYYY";
char pass[] = "ZZZZ";
#define relePin 13  //D7 RELAY
int pirState;
int val;
int x;  // V0
BLYNK_CONNECTED() {
BLYNK_WRITE(V0){
 x = param.asInt();
void PIRval(){
    if (val == HIGH)
      else {
void setup(){
void loop(){
WIRING SLAVE - PIN ON NODE
D5–> signal for PIR on slave nodemcu
D6 --> signal for led on slave nodemcu
CODING ON SLAVE
 * MODULE  PIR ONLY (SLAVE)
 * 1 LED
 * 1 PIR
 * AppName:MODULO PIRONLY - XXXXX
char auth[] = "XX";
char ssid[] = "YY";
char pass[] = "ZZ";
int pirState;
int val;
int x;  // V0
BLYNK_CONNECTED() {
  bridge1.setAuthToken("XXXX11");
BLYNK_WRITE(V0){
 x = param.asInt();
void PIRval(){
    if (val == HIGH) {
      bridge1.digitalWrite(14, HIGH); //D5
      else {
        bridge1.digitalWrite(14, LOW); //D5
void setup(){
void loop(){
Result:
if Slave PIR is triggered it correctly activate the relay on master
if mastr PIR is triggered notthing happen.
It seems your are trying to make the pirPin on the master go high when the pir on the slave detects motion.
Why not just set the relePin High with the bridge.
bridge1.digitalWrite(13, HIGH); //D7
There may be some conflict occurring when the Master device is trying to read the digital pin (INPUT) and the slave is trying to drive it.
Although that may not solve the issue, as it with just turn off. I think you may need to rethink the logic in the code.
Here is a quick example of how I would do it. NOTE: these are just snippets and will need to be placed in the appropriate places in your code.
I am also assuming you have them wired correctly, and with the appropriate pullup or pulldown resistor as needed.
ON SLAVE
if (val == HIGH) {
      bridge1.virtuallWrite(V10, 1); //set Virtual Pin 10 to 1
else {
        bridge1.virtuallWrite(V10, 0); //set Virtual Pin 10 to 0
ON MASTER
int slavePIR;
BLYNK_WRITE(V10){
 slavePIR = param.asInt();
    if (val == HIGH || slavePIR == 1)
Hi Everybody,
I made some changes and review based on Toro_Blanco advice (thank you).
Now everythinks look good.
Just to small bugs:
  1. The Led on the IR only Nodemcu when triggered by the Master NodeMcu is blinking
  2. (muchmore rilevant) Often the IR only NodeMCU goes OFF line. I Think there is somethink is the code that generates problem…
Here updates (working codes)… is there anybody can look into?
best
IR ONLY - SLAVE
 * 1 LED
 * 1 PIR
char auth[] = "x";
char ssid[] = "y";
char pass[] = "z";
int val;
BLYNK_CONNECTED() {
  bridge1.setAuthToken("x2");
void PIRval(){
if (val == HIGH) {
      bridge1.virtualWrite(V10, 1); //set Virtual Pin 10 to 1
else {
        bridge1.virtualWrite(V10, 0); //set Virtual Pin 10 to 0
void setup(){
void loop(){
RELE NODEMCU - MASTER CODE
/* WiFi credentials */
char auth[] = "Xxxx";
char ssid[] = "YY";
char pass[] = "zz";
#define ledPin 13    // D7 Led
#define pirPin 5     // D1 Input for Micro PIR
#define relePin 12   // D6 Rele
int pirValue;        // Place to store read PIR Value
int slavePIR;        // where PIR Value is stored from other device
BLYNK_WRITE(V10){
WidgetBridge bridge2(V1);     //NEW
BLYNK_CONNECTED() {           //NEW
  bridge2.setAuthToken("XX1"); //NEW
  timer.setInterval (1000L, getPirValue);
  getPirValue();
 * Get PIR data
void getPirValue(void)
  pirValue = digitalRead(pirPin);
 if (pirValue || slavePIR == 1) {
      bridge2.digitalWrite(12, 255);
else {
      bridge2.virtualWrite(12, 0);
Here the output in a video: https://youtu.be/ISSa56o-rQQ
Remove getPirValue() from the loop, as this is calling it many times/second. You are already calling it once/second with the timer.
Also, change SimpleTimer timer; to BlynkTimer timer; and remove #include <SimpleTimer.h> in both sketches, as it is not needed. Blynk has the timer built into its library already.
And since you basically want them both to do the same thing (turn on both relays/leds if a motion is detected by either PIR), I would have both codes almost the same. Just changing pins and auth tokes where necessary.
char ssid[] = "YY";
char pass[] = "zz";
int otherPIR;        // where PIR Value is stored from other device
  // Place the AuthToken of the other hardware here
BLYNK_WRITE(V10){
 otherPIR = param.asInt();
 * Get PIR data
void getPirValue()
 if (pirValue == 1 || otherPIR == 1) {
      bridge2.virtualWrite(10, 1);
else {
      bridge2.virtualWrite(10, 0);
  timer.setInterval (500L, getPirValue); //every half second
Hi Toro_Blanco, thank you for your insight. Now everythink works correctly… Super!
just a small question… I want introduce 10 sec of dealy that basically keeps the relay on when triggerd.
Is the dealy in this case ok or not?
best
 * Get PIR data
      delay(10000);
Not, this will cause connection issues. You need to use simpletimer functions.
So basically when motion is detected the relay will turn on, and stay on, for 10 seconds after no motion has been detected?
YES
A timeout timer that starts after activating the relay and 10 seconds later calls a function that cancels the relay is what you need.
https://playground.arduino.cc/Code/SimpleTimer#F_setTimeout
Here is how I would do it. I changed some of the code, as I think the previous code was flawed. To me it seems like the previous code would not allow the relay to turn off.
void getPirValue()
 if (pirValue == 1 ) {
else if (otherPIR == 1){
else {
timer.setTimeout(10000L, []() {  // Run after 10 seconds
  });  // END Timer Function
