Help me to send this analog data to blynk
I try to do simple coding, receive data from sensor and send to blynk app. When I do without connection of blynk, the serial monitor show range of result from 500-600. As I connect with blynk, 0 value remains. Can you help why?
 #define BLYNK_TEMPLATE_ID "TMPLUbWIVa-J"
#define BLYNK_DEVICE_NAME "IoT Sound Monitoring"
#define BLYNK_AUTH_TOKEN "X1M4kjMcKWngRCBVHyaWFZecNuVt47cY"
  #include <WiFi.h>
  #include <WiFiClient.h>
  #include <BlynkSimpleEsp32.h>
  char ssid[] = "akmalijat0_2.4GHz@unifi";
  char pass[] = "Hyperjackie12#";
  const byte soundpin=4;
  pinMode (soundpin,INPUT);
  Serial.begin (115200);
   timer.setInterval(1000L,sensorDataSend);
void sensorDataSend(){
  int sample= analogRead(soundpin);
  Serial.print(sample);
  Serial.print("\n");
  Blynk.virtualWrite(V0,sample);
0
0
0
0
0
0
Please don’t create multiple topics on the same subject, keep the discussion in one place.
@Aidid I’ve advised you against creating multiple topics on the same subject before.
Please regard this as your final warning. If you continue to do this I will suspend your login to this forum for 1 week.
