So, my project is monitoring garden system, im using notify in blynk and led as the output following the sensor value. I want to make, if blynk notify and led is ON, i want the LCD display the notify too, but im confused with the code. The LCD will display notify following the blynk notify and LED, if its not, the LCD will display the sensor value
Im using :
• Nodemcu ESP8266, DHT 22 Sensor, Soil Moisture sensor (im using the A0,VCC, and GND), 2 LED, 1 LCD with I2C
• Smartphone Android
• Blynk Library version
#include <DHT.h>
#include <Wire.h>
char auth[] = "9wiBL8RDQjWOnIHOaCIn4Szb0Ekw_n2Z"; //Enter the Auth code which was send by Blink
char ssid[] = "GARPU_SIOMAY"; //Enter your WIFI Name
char pass[] = "katasandi"; //Enter your WIFI Password
#define DHTPIN 2 // Digital pin 4
const int sensorpin = A0; //Analog Pin
int greenLed = 14; // Digital Pin 5
int yellowLed = 12; // Digital Pin 6
int sensorvalue=0;
int outputvalue=0;
LiquidCrystal_I2C lcd(0x3F, 16, 2);
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
const int sensorPin = A0;
// This function sends Arduino's up time every second to Virtual Pin.
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h); //V5 is for Humidity
Blynk.virtualWrite(V6, t); //V6 is for Temperature
lcd.setCursor(0, 0);
lcd.print("Humid=");
lcd.setCursor(10, 0);
lcd.print(h);
// Pindahkan kursor ke baris berikutnya dan cetak lagi
lcd.setCursor(0, 1);
lcd.print("Temp=");
lcd.setCursor(10, 1);
lcd.print(t);
void sendSensor2()
int greenLed = 14;
int yellowLed = 12;
int sensorvalue=analogRead(sensorpin);
outputvalue=map(sensorvalue,0,1023,0,100);
digitalWrite(greenLed, HIGH);
digitalWrite(yellowLed, LOW);
if(outputvalue>74)
Serial.println("Please give me water");
Serial.print(outputvalue);
digitalWrite(yellowLed, HIGH);
digitalWrite(greenLed, LOW);
Blynk.notify("Please give me water");
delay(60000); //delay notifikasi
else if(outputvalue<45)
Serial.println("Soil is wet enough to water");
Blynk.notify("Soil is wet enough to water");
delay(60000);// delay notifikasi
Blynk.virtualWrite(V1, outputvalue);
pinMode(yellowLed, OUTPUT);
pinMode(greenLed, OUTPUT);
dht.begin();
lcd.begin(16,2);
timer.setInterval(2000L, sendSensor);
timer.setInterval(1000L, sendSensor2);
I’ve tried the code, but i have an error
invalid conversion from ‘int’ to ‘t_backlighPol’ [-fpermissive]
Please help
