My project use 2 Node MCU ( Node MCU 1 and Node MCU 2).Node MCU 2 revieved the sensor value from Photoresister(@A0 Pin).But If don’not edit code and run code following below
Haha I’m weak in English I want to use sensor value @A0 pin form Node MCU 2 to controll PWM @ D2 pin in Node MCU 1 But I dob’t Know to Edit my code? what should I do.
Now I want to use the value from V5 pin to program in void loop .In this case I use V4 pin to connect between 2 loop BLYNK_WRITE(V5){…} loop and void loop{…} loop. But when slide V5 in app to 255 V4 does not respond .
What should I do.
char auth[] = "cc0e05e8371e4a858e07c69c611116dd";
int sensorPin = A0;
int sensorValue =0;
WidgetBridge bridge1(V1);
Blynk.begin(auth, "Connectify-", "ap1234567");
BLYNK_CONNECTED() {
bridge1.setAuthToken("2a97e454d9de4fd791844b92bae8a7e9"); // Token of the hardware B
BLYNK_WRITE(V5)
int value = param.asInt();
Serial.print("V5 value in loop ;");
Serial.println(value);
Blynk.virtualWrite(V4, value);
int sensorValue = analogRead(sensorPin);
Serial.println("sensorValue MAIN loop ;");
Serial.println(sensorValue);
bridge1.analogWrite(4,sensorValue);
int value1=analogRead(V4);
Serial.println("V4 value OUT loop ;");
Serial.println(value1);
@ap10127700 before I look at your code can you please confirm you have the Bridge widget in each of the projects on the Smartphone.
Also:
Why have you got more than 2 lines in the loop() when almost all the Blynk examples only have 2?
Do you know what SimpleTimer is, i.e. one of the 4 libraries that you must install (manually) if you want to use Blynk for anything more than blinking an LED?
Why is you sketch so badly commented, what is V4 , V5, hardware A, hardware B?
1.Get sensor (Analog input) value and sent this value to device B to dimming RED LED(@D2 PIn)--------complete
2.Get the value from BLYNK_WRITE(V5) and promgram for automatic dimming and command automatic dimming to DEVICE B to BLUE LED (@D3 Pin) I will add BLUE LED in future
-------------------------------------------------------------------------------------------------------------------------------------------not complete!!!
(I want to program automatic dimming in void loop use the value from V5 Pin in DEVICE A)
int sensorPin = A0;
int sensorValue =0;
BLYNK_CONNECTED() {
BLYNK_WRITE(V5)
DEVICE B
1.GET value from DEVIE A to dimming RED and BLUE LED
char auth[] = "2a97e454d9de4fd791844b92bae8a7e9";
BLYNK_WRITE(V5){
int pinData = param.asInt(); // pinData variable will store value that came via Bridge
if(pinData == 1){
// do something
else{
// do something different
You can pass integers, double, floats and strings.
Do not consider putting any of this, or anything else in loop().
With SimpleTimer and an interval of say 500ms call a function such as this:
void checkV5(){
Blynk.syncVirtualV5); // this "refreshes" V5
If you are physically connecting device A with device B you don’t actually need bridge but it is probably useful for you to learn how it works.
