Hi Blynk Community,
I’m having trouble connecting my ESP32 to the Blynk Cloud using the BlynkLib library. Here are the details of my setup and the issues I’m facing:
Setup:
- Device: ESP32
- Firmware Version: 1.23.0
- Blynk Library Version: BlynkLib (for MicroPython)
- Wi-Fi Network:
- SSID: Nitro5
- Password: 0837472950
- Blynk Auth Token: Rh95uvWr9KWY3F0ubyG2Vq1JkGhVnxqh
Issue:
I am attempting to connect to the Blynk Cloud using the following code:
python
import network
import BlynkLib
from machine import Pin
import time
# Wi-Fi credentials
SSID = 'Nitro5'
PASSWORD = '0837472950'
def connect_wifi():
wlan = network.WLAN(network.STA_IF)
wlan.active(True)
wlan.connect(SSID, PASSWORD)
print('Connecting to WiFi...', end='')
while not wlan.isconnected():
print('.', end='')
time.sleep(1)
print(' Connected!')
print('Network config:', wlan.ifconfig())
# Connect to Wi-Fi
connect_wifi()
# Blynk Auth Token
BLYNK_AUTH = 'Rh95uvWr9KWY3F0ubyG2Vq1JkGhVnxqh'
# Initialize Blynk
# Register virtual pin handler
@blynk.VIRTUAL_WRITE(3)
def v3_write_handler(value):
print('Current slider value: {}'.format(value[0]))
# Main loop
while True:
try:
blynk.run()
except Exception as e:
print("An error occurred:", e)
time.sleep(0.1)
