I am using MQ135 gas sensor and ESP8266 nodeMCU with Blynk App to detect smoke, which should notify on my app if the value sensed exceeds 600. The sensor is able to sense values but my app does not get notified.
I am using the circuit and instructions in this link.
Code for reference:
//#include <SimpleTimer.h>
char auth[] = "***************";
/* WiFi credentials */
char ssid[] = "*************";
char pass[] = "*************";
int mq135 = A0; // smoke sensor is connected with the analog pin A0
int data = 0;
timer.setInterval(1000L, getSendData);
void getSendData()
data = analogRead(mq135);
Blynk.virtualWrite(V2, data); //virtual pin V3
if (data > 600)
Blynk.notify("Smoke Detected!!!");
