Help for modify RGB widget
Hi everyone
finally someone explained well how the RGB widget works
RGB Light Control for Mobile: Widget Functionality and Code Examples…
Hi try and work well but now I would like to control a led strip (fasteled library) that does not have three pins to control RGB but only one. Can someone help me modify the code?
kind regards
I’d say that the first step is for you to explain much more about the LED strip that you’re using.
Hi Pete
I use a BTF-LIGHTING WS2811 is a strip led with three pins 12v, Din, GND
King Regards
look for ‘WS2811 LEDS +tutorial’, there is plenty of info and examples on the internet.
Hi pierredebuysscher
I know how to control a led strip, I want to modify this code
RGB Light Control for Mobile: Widget Functionality and Code Examples …
that works very well for a non-digital led to use the RGB widget that I think is really very nice.
I just need to modify it for a single digital LED
King Regards
