Urgent: Does anyone know how to fix the “Device is offline” status on Blynk? Everything is literally fine, the code and connections are all good but I keep getting this message. The board I’m using is the ESP32 dev and I’m trying to sense a DHT11 and an MQ2 gas sensor. The code and everything on the Blynk side is fine. Does anyone know a step-by-step solution that can help me, either written or by video?
Code:
// Template and device credentials for Blynk
#define BLYNK_TEMPLATE_ID "TMPL6YAS5_ss3"
#define BLYNK_TEMPLATE_NAME "IoT Smart Exhaust Fan"
#define BLYNK_PRINT Serial // Directs Blynk messages to the serial port
#include <WiFi.h> // Include WiFi library for ESP32
#include <BlynkSimpleEsp32.h> // Include Blynk ESP32 library
#include "DHT.h" // Include DHT sensor library
// Blynk and WiFi credentials
const char auth[] = "*****************"; // Blynk authentication token
const char ssid[] = "*****************"; // WiFi SSID
const char pass[] = "*****************"; // WiFi password
// Pin configuration
#define DHTPIN 22 // DHT sensor pin
#define DHTTYPE DHT11 // Type of DHT sensor
const int gasSensorPin = 34; // Gas sensor pin
const int relayPin = 23; // Relay module pin
const int gasThreshold = 20; // Gas level threshold for triggering the relay
DHT dht(DHTPIN, DHTTYPE); // Initialize DHT sensor
bool manualMode = false; // Flag to track if the relay is in manual mode
Serial.begin(115200); // Start serial communication at 115200 baud rate
dht.begin(); // Initialize DHT sensor
Blynk.begin(auth, ssid, pass); // Connect to Blynk using WiFi
pinMode(relayPin, OUTPUT); // Set relay pin as output
pinMode(gasSensorPin, INPUT); // Set gas sensor pin as input
digitalWrite(relayPin, LOW); // Ensure relay is off initially
delay(2000); // Wait for 2 seconds before proceeding
// Function to handle manual relay control from Blynk app
BLYNK_WRITE(V4)
int relayControl = param.asInt(); // Get value from Blynk app
manualMode = (relayControl == 1); // Set manual mode based on app input
if (manualMode)
digitalWrite(relayPin, HIGH); // Turn on relay in manual mode
digitalWrite(relayPin, LOW); // Turn off relay when exiting manual mode
Blynk.virtualWrite(V3, relayControl); // Update relay status on Blynk
Blynk.run(); // Run Blynk
int sensorValue = analogRead(gasSensorPin); // Read gas sensor value
int gas_percentage = map(sensorValue, 0, 4095, 0, 100); // Convert to percentage
float humidity = dht.readHumidity(); // Read humidity from DHT sensor
float temperature = dht.readTemperature(); // Read temperature from DHT sensor
// Check if sensor readings are valid
if (isnan(humidity) || isnan(temperature))
Serial.println(F("Failed to read from DHT sensor!"));
return;
// Print sensor values to the Serial Monitor
Serial.print("Humidity: ");
Serial.print(humidity);
Serial.println("%");
Serial.print(temperature);
Serial.println("°C ");
Serial.print("Gas sensor value: ");
Serial.println(sensorValue);
Serial.print("Gas Percentage: ");
Serial.print(gas_percentage);
Serial.println();
// Automatic control logic based on gas levels
if (!manualMode)
if (gas_percentage > gasThreshold)
digitalWrite(relayPin, HIGH); // Activate relay if gas above threshold
Blynk.virtualWrite(V3, HIGH); // Update Blynk app
digitalWrite(relayPin, LOW); // Deactivate relay if gas below threshold
Blynk.virtualWrite(V3, LOW); // Update Blynk app
// Send sensor values to Blynk
Blynk.virtualWrite(V0, gas_percentage); // Send gas percentage
Blynk.virtualWrite(V1, temperature); // Send temperature
Blynk.virtualWrite(V2, humidity); // Send humidity
delay(1000); // Wait for a second before next loop iteration
