This is the sketch…
#define RECUPERATORE 34 // RECUPERATORE
#define VEL_REC 12 // VELOCITA' RECUPERATORE
#define PDC_RISC 38 // PDC RISCALDAMENTO
#define PDC_RAFFR 40 // PDC RAFFRESCAMENTO
#define DEUM 35 // DEUMIDIFICATORE
#define VALVOLA_DEUM 43 // VALVOLA DEUMIDIFICATORE
#define TESTINE_CASA 41 // TESTINE CASA
#define TESTINE_CAMERA 39 // TESTINE CAMERA
#define TESTINE_TAVERNA 36 // TESTINE TAVERNA
#define TESTINE_BAGNO_TAVERNA 37 // TESTINE BAGNO TAVERNA
#define T1_UP 22 // TAPPARELLA 1 SU
#define T1_DOWN 23 // TAPPARELLA 1 GIU
#define T2_UP 24 // TAPPARELLA 2 SU
#define T2_DOWN 25 // TAPPARELLA 2 GIU
#define T3_UP 28 // TAPPARELLA 3 SU
#define T3_DOWN 27 // TAPPARELLA 3 GIU
#define T4_UP 26 // TAPPARELLA 4 SU
#define T4_DOWN 29 // TAPPARELLA 4 GIU
#define T5_UP 30 // TAPPARELLA 5 SU
#define T5_DOWN 31 // TAPPARELLA 5 GIU
#define T6_UP 32 // TAPPARELLA 6 SU
#define T6_DOWN 33 // TAPPARELLA 6 GIU
#define ISTERESI_T 0.5 // ISTERESI TEMPERATURA
#define ISTERESI_H 5 // ISTERESI UMIDITA
#include <UIPEthernet.h>
#include <BlynkSimpleUIPEthernet.h>
#include <ESP8266_Lib.h>
char ssid[] = "FESSO_CHI_LEGGE";
char pass[] = "xxxxxxxxxxxxxxx";
#define EspSerial Serial1
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
#include <DHT.h>
#include <PZEM004T.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
IPAddress ip(192,168,1,1);
char auth[] = "xxxxxxxxxxxxxxx";
//il server è 192, 168, 0, 10. forwarding da 192, 168, 10, 4
IPAddress server_ip (192, 168, 10, 4);
byte arduino_mac[] = { 0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
IPAddress arduino_ip ( 192, 168, 10, 5);
IPAddress dns_ip ( 8, 8, 8, 8);
IPAddress gateway_ip ( 192, 168, 10, 1);
IPAddress subnet_mask(255, 255, 255, 0);
#define DHTCAMERAPIN 3 // SENSORE CAMERA
#define DHTCASAPIN 4 // SENSORE CASA
#define DHTTAVERBAPIN 9 // SENSORE TAVERNA
#define DHTEXTPIN 2 // SENSORE ESTERNO
#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
DHT sensore_camera(DHTCAMERAPIN, DHTTYPE);
DHT sensore_casa(DHTCASAPIN, DHT11);
DHT sensore_taverna(DHTTAVERBAPIN, DHTTYPE);
DHT sensore_ext(DHTEXTPIN, DHTTYPE);
WidgetRTC rtc;
PZEM004T pzem(10,11); // (RX,TX) connect to TX,RX of PZEM
bool autom, flaginvio;
unsigned long intervallo_rec;
int mode, velocita, velocita1, velocita2, velocita3, velocita4, count,setpointh;
void stop_clima();
void on_inverno();
void on_estate();
void stop_rec(),tempo_recuperatore(),on_rec();
void opentap(),closetap(),offtap();
float h_cam,t_cam,h_tav,t_tav,h_casa,t_casa,h_ext,t_ext,e, energia=0,setpointtaverna, setpointcamera;
int t1_h,t1_m,t2_h,t2_m,t3_h,t3_m,t1stop_h,t1stop_m,t2stop_h,t2stop_m,t3stop_h,t3stop_m;
int dayinvio=10;
int eprec=0;
int euro=24;
/////////////////////////////////////////////////////IFTT////////////////////////////////////////////////////////////////////////////////
BLYNK_WRITE(V36){
switch (param.asInt()) {
case 1: //pulsante accensione spot recuperatore
velocita=velocita1; //imposto la velocità spot
autom=LOW; //disabilito modalita auto per abilitare counter
on_rec(); //chiamo funzione per accendere
break;
case 2: //pulsante alza tap
opentap();
delay (1000);
offtap();
break;
case 3: //pulsante abbassa tap
closetap();
delay (1000);
offtap();
break;
case 4: //pulsante abbassa tap
closetap();
delay (500);
offtap();
break;
/////////////////////////////////////////////////////INVIO MAIL////////////////////////////////////////////////////////////////////////////////
void invio_mail()
String currentTime = String(hour()) + ":" + minute() + ":" + second(); //orario e data
Blynk.virtualWrite(V40, currentTime);
Blynk.virtualWrite(V41, currentDate);
if(hour()==dayinvio&&flaginvio==true){Serial.println("INVIO!!"); //controllo che si il giorno dell'invio e che non sia già stata inviata
flaginvio=false;
String body = String("Energia consumata nel mese ") + month() + String("= ") + e + " wh.";
Blynk.email("xxxxxxxxxxxxx@gmail.com", "Consumo mensile Energia", body);
if(hour()!=dayinvio){flaginvio=true;}
/////////////////////////////////////////////////////AMPEROMETRICA////////////////////////////////////////////////////////////////////////////////
void amp(){
e = pzem.energy(ip); //energia
if(e >= 0.0){ Serial.print(e);Serial.print("Wh; ");
Blynk.virtualWrite(V37, e*0.001);
Blynk.virtualWrite(V38, e*euro*0.01*0.001); //energia*euro
float p = pzem.power(ip); //potenza
if(p >= 0.0){ Serial.print(p);Serial.print("W; ");
Blynk.virtualWrite(V39, p);}
Serial.println();
/////////////////////////////////////////////////////TAPPARELLE////////////////////////////////////////////////////////////////////////////////
BLYNK_WRITE(V32) { opentap();
delay (1000);
offtap();
Blynk.virtualWrite(V32, LOW);} //apri, dopo 500ms spegni rele e spegni pulsante
BLYNK_WRITE(V33) { opentap();
delay (500);
offtap(); //apri, dopo 100ms spegni rele serve per fermare
//timer.setTimeout(4000L, []() {closetap();delay (500);offtap();} ); //dopo 4s: chiudi, dopo 500ms spegni rele
Blynk.virtualWrite(V33, LOW); }
BLYNK_WRITE(V34) { closetap();
delay (1000);
offtap();
Blynk.virtualWrite(V34, LOW);} //chiudi, dopo 500ms spegni rele e spegni pulsante
/////////////////////////////////////////////////////SENSORI////////////////////////////////////////////////////////////////////////////////
void sendSensor()
{ h_cam = sensore_camera.readHumidity(); //lettura sensori
t_cam = sensore_camera.readTemperature();
h_tav = sensore_taverna.readHumidity();
t_tav = sensore_taverna.readTemperature();
h_casa = sensore_casa.readHumidity();
t_casa = sensore_casa.readTemperature();
h_ext = sensore_ext.readHumidity();
t_ext = sensore_ext.readTemperature();
if (isnan(h_cam)||isnan(t_cam)||isnan(h_casa)||isnan(t_casa)||isnan(h_ext)||isnan(t_ext)||isnan(h_tav)||isnan(t_tav)) { Serial.println("Failed to read from DHT sensor!");}
Blynk.virtualWrite(V5, h_cam); //scrittura su widget
Blynk.virtualWrite(V6, t_cam);
Blynk.virtualWrite(V29, h_casa);
Blynk.virtualWrite(V28, t_casa);
Blynk.virtualWrite(V27, h_ext);
Blynk.virtualWrite(V26, t_ext);
Blynk.virtualWrite(V15, t_tav);
Blynk.virtualWrite(V14, h_tav);
/////////////////////////////////////////////////////CLIMA////////////////////////////////////////////////////////////////////////////////
void ctrl()
{ if (mode==2){ on_inverno();
if (t_cam<=setpointcamera-ISTERESI_T){ digitalWrite (TESTINE_CAMERA, HIGH);
Blynk.virtualWrite(V11, 1);
if (t_cam>=setpointcamera){ digitalWrite (TESTINE_CAMERA, LOW);
Blynk.virtualWrite(V11, 0);
if (t_tav<=setpointtaverna-ISTERESI_T){ digitalWrite (TESTINE_TAVERNA, HIGH);
Blynk.virtualWrite(V13, 1);
if (t_tav>=setpointtaverna){ digitalWrite (TESTINE_TAVERNA, LOW);
Blynk.virtualWrite(V13, 0);
if (mode==3){ on_estate();
if (h_casa<=setpointh){ digitalWrite (DEUM, LOW);
digitalWrite (VALVOLA_DEUM, LOW);
Blynk.virtualWrite(V25, 0);
if (h_casa>=setpointh+ISTERESI_H){ digitalWrite (DEUM, HIGH);
digitalWrite (VALVOLA_DEUM, HIGH);
Blynk.virtualWrite(V25, 1);
if (mode==1)stop_clima();
BLYNK_WRITE(V10) { setpointcamera=param.asFloat();}
BLYNK_WRITE(V12) { setpointtaverna=param.asFloat();}
BLYNK_WRITE(V35) { setpointh=param.asInt();}
BLYNK_WRITE(V0) { mode=param.asInt(); } //widget selezione modalita
//////////////////////////////////////////////////////////////////RECUPERATORE/////////////////////////////////////////////////////////////////////////////////////////
BLYNK_WRITE(V1){ //pulsante accensione spot recuperatore
if (param.asInt()==HIGH) {velocita=velocita1; //imposto la velocità spot
else stop_rec();
void ctrl_recuperatore() //funzione controllo timer
if (t1_h==hour()&&t1_m==minute()&&digitalRead(RECUPERATORE)==LOW){autom=HIGH; //abilito modalita auto per non entrare nel counter
velocita=velocita2; //imposto la velocità
on_rec(); }
if (t2_h==hour()&&t2_m==minute()&&digitalRead(RECUPERATORE)==LOW){autom=HIGH; //abilito modalita auto per non entrare nel counter
velocita=velocita3; //imposto la velocità
on_rec(); }
if (t3_h==hour()&&t3_m==minute()&&digitalRead(RECUPERATORE)==LOW){autom=HIGH; //abilito modalita auto per non entrare nel counter
velocita=velocita4; //imposto la velocità
on_rec(); }
if ((t1stop_h==hour()&&t1stop_m==minute()&&digitalRead(RECUPERATORE)==HIGH)||
(t2stop_h==hour()&&t2stop_m==minute()&&digitalRead(RECUPERATORE)==HIGH)||
(t3stop_h==hour()&&t3stop_m==minute()&&digitalRead(RECUPERATORE)==HIGH))stop_rec();
Blynk.virtualWrite(V22, digitalRead (RECUPERATORE)*velocita/51); //grafico il pin di comando al rec
void on_rec()
{ Blynk.virtualWrite(V1, 1); //accendo pulsante
digitalWrite (RECUPERATORE, HIGH); //accendo recuperatore
analogWrite (VEL_REC,velocita ); //imposto velocita
Blynk.virtualWrite(V7, velocita/51);} //scrivo velocita su widget
void stop_rec()
{ digitalWrite (RECUPERATORE, LOW); //spengo recuperatore
Blynk.virtualWrite(V1, 0); //spengo pulsante
Blynk.virtualWrite(V7, 0); //scrivo vel 0%
count=0;}
void tempo_recuperatore() //funzione per spegnere rec dopo tot tempo
{ if (autom==LOW){ if (count>=intervallo_rec){stop_rec(); //inizio a contare se la modalita auto è disabilitata
count=0;
else count++;}}
BLYNK_WRITE(V4){velocita1 = 51*param.asInt();} //slider velocità spot, 5 velocità->51*5=255
BLYNK_WRITE(V9){velocita2 = 51*param.asInt();} //slider velocità orario 1, 5 velocità->51*5=255
BLYNK_WRITE(V18){velocita3 = 51*param.asInt();} //slider velocità orario 2, 5 velocità->51*5=255
BLYNK_WRITE(V20){velocita4 = 51*param.asInt();} //slider velocità orario 3, 5 velocità->51*5=255
BLYNK_WRITE(V8){intervallo_rec = param.asInt();} //tempo attività recuperatore modalità spot
BLYNK_WRITE(V42) {TimeInputParam t(param);
t1_h=t.getStartHour();
t1_m=t.getStartMinute();
t1stop_h=t.getStopHour();
t1stop_m=t.getStopMinute();}
BLYNK_WRITE(V43) {TimeInputParam t(param);
t2_h=t.getStartHour();
t2_m=t.getStartMinute();
t2stop_h=t.getStopHour();
t2stop_m=t.getStopMinute();}
BLYNK_WRITE(V44) {TimeInputParam t(param);
t3_h=t.getStartHour();
t3_m=t.getStartMinute();
t3stop_h=t.getStopHour();
t3stop_m=t.getStopMinute();}
void graph()
//LAN
//Blynk.begin(auth, "192.168.10.4", 8080);
//Blynk.begin(auth, "192.168.0.10", 8080);
Blynk.begin(auth, server_ip, 8080, arduino_ip, dns_ip, gateway_ip, subnet_mask, arduino_mac);
//wifi
Blynk.begin(auth, wifi, ssid, pass, "192.168.0.10", 8080);
//sincronizzazione orario
setSyncInterval(10 * 60); // Sync interval per il controllo del tempo(10 minutes)
//inizializazine pin uscita
pinMode(PDC_RISC, OUTPUT);
digitalWrite (PDC_RISC, LOW);
pinMode(PDC_RAFFR, OUTPUT);
digitalWrite (PDC_RAFFR, LOW);
pinMode(DEUM, OUTPUT);
pinMode(VALVOLA_DEUM, OUTPUT);
pinMode(TESTINE_CASA, OUTPUT);
digitalWrite (TESTINE_CASA, LOW);
pinMode(TESTINE_CAMERA, OUTPUT);
pinMode(TESTINE_TAVERNA, OUTPUT);
pinMode(TESTINE_BAGNO_TAVERNA, OUTPUT);
digitalWrite (TESTINE_BAGNO_TAVERNA, LOW);
pinMode(T1_UP, OUTPUT);
digitalWrite (T1_UP, LOW);
pinMode(T1_DOWN, OUTPUT);
digitalWrite (T1_DOWN, LOW);
pinMode(T2_UP, OUTPUT);
digitalWrite (T2_UP, LOW);
pinMode(T2_DOWN, OUTPUT);
digitalWrite (T2_DOWN, LOW);
pinMode(T3_UP, OUTPUT);
digitalWrite (T3_UP, LOW);
pinMode(T3_DOWN, OUTPUT);
digitalWrite (T3_DOWN, LOW);
pinMode(T4_UP, OUTPUT);
digitalWrite (T4_UP, LOW);
pinMode(T4_DOWN, OUTPUT);
digitalWrite (T4_DOWN, LOW);
pinMode(T5_UP, OUTPUT);
digitalWrite (T5_UP, LOW);
pinMode(T5_DOWN, OUTPUT);
digitalWrite (T5_DOWN, LOW);
pinMode(T6_UP, OUTPUT);
digitalWrite (T6_UP, LOW);
pinMode(T6_DOWN, OUTPUT);
digitalWrite (T6_DOWN, LOW);
//inizializazine sensori temp h
sensore_camera.begin();
sensore_taverna.begin();
sensore_casa.begin();
sensore_ext.begin();
//richiamo funzioni ogni tot ms
timer.setInterval(10000L, invio_mail); //frequenza controllo invio mail
flaginvio=true;
timer.setInterval(10000L, sendSensor); //frequenza aggiornamento sensori
timer.setInterval(10000L, ctrl); //frequenza aggiornamento controllo clima
timer.setInterval(5000L, amp); //frequenza aggiornamento consumi elettrici
//recuperatore
pinMode(RECUPERATORE, OUTPUT);
pinMode(VEL_REC, OUTPUT);
count=0;
autom=HIGH;
timer.setInterval(60000L, tempo_recuperatore); //contatore recuperatore ogni minuto modalità spot
timer.setInterval(3000L, ctrl_recuperatore); //controllo tempo timer recuperatore ogni 3s
BLYNK_CONNECTED() { //sincronizza le variabili appena arduino si connette al server
Blynk.syncVirtual(V4,V9,V18,V20,V8,V1,V42,V43,V44); //RECUPERATORE
Blynk.syncVirtual(V0,V10,V12,V35); //CLIMA
rtc.begin();
Blynk.email("xxxxxxxxxxxx@gmail.com", "Connessione Blynk", "Arduino Mega si è collegato al server Local Blynk");
void loop(){
void on_inverno(){
digitalWrite (PDC_RISC, HIGH);
Blynk.virtualWrite(V23, 1);
Blynk.virtualWrite(V24, 0);
digitalWrite (TESTINE_CASA, HIGH);
Blynk.virtualWrite(V30, 1);
// digitalWrite (TESTINE_CAMERA, !HIGH);
//Blynk.virtualWrite(V11, 1);
// digitalWrite (TESTINE_TAVERNA, !HIGH);
digitalWrite (TESTINE_BAGNO_TAVERNA, HIGH);
Blynk.virtualWrite(V31, 1);
void on_estate(){
Blynk.virtualWrite(V23, 0);
digitalWrite (PDC_RAFFR, HIGH);
Blynk.virtualWrite(V24, 1);
//digitalWrite (DEUM, !HIGH);
//digitalWrite (VALVOLA_DEUM, !HIGH);
Blynk.virtualWrite(V31, 0);
void stop_clima(){
Blynk.virtualWrite(V30, 0);
void opentap(){
Serial.println("ALZA");
digitalWrite (T1_UP, HIGH);
digitalWrite (T2_UP, HIGH);
digitalWrite (T3_UP, HIGH);
digitalWrite (T4_UP, HIGH);
digitalWrite (T5_UP, HIGH);
// digitalWrite (T6_UP, HIGH);
// digitalWrite (T6_DOWN, LOW);
void closetap(){
Serial.println("ABBASSA");
digitalWrite (T1_DOWN, HIGH);
digitalWrite (T2_DOWN, HIGH);
digitalWrite (T3_DOWN, HIGH);
digitalWrite (T4_DOWN, HIGH);
digitalWrite (T5_DOWN, HIGH);
// digitalWrite (T6_UP, LOW);
// digitalWrite (T6_DOWN, HIGH);
void offtap(){
Serial.println("FERMA");
