Hi I would like to share my project with you … an added code for Sinric, with blynk and ifttt and Google home are already working. Give me a hand to see if I have it spelled correctly. Thank you
I should point out that it must work as a Button not as a Switch because it is mounted on a domestic system where there are relays for this I have set the time function in the google home command section (ifttt) and are working
#include <ESP8266mDNS.h> //per aggiornamenti OTA
#include <WiFiUdp.h> //per aggiornamenti OTA
#include <ArduinoOTA.h> //per aggiornamenti OTA
#include <WebSocketsClient.h> //per sinric
#include <ArduinoJson.h> //per sinric
#include <Arduino.h> //per sinric
#include <ESP8266WiFiMulti.h> //per sinric
#include <StreamString.h> //per sinric
//inizio programmazione sinric
ESP8266WiFiMulti WiFiMulti;
WebSocketsClient webSocket;
WiFiClient client;
#define HEARTBEAT_INTERVAL 300000 // 5 Minutes
uint64_t heartbeatTimestamp = 0;
bool isConnected = false;
#define MyApiKey "643642exxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" // TODO: Change to your sinric API Key. Your API Key is displayed on sinric.com dashboard
#define MySSID "xxxxxxxxxxxxxxx" // TODO: Change to your Wifi network SSID
#define MyWifiPassword "xxxxxxxxxxxxxx" // TODO: Change to your Wifi network password
#define luce_salotto "5d139fxxxxxxxxxxxxxxxxxx" //TODO: Device ID of PRIMO device (R1 Luce Salotto)
#define luce_cucina_isola "5d1xxxxxxxxxxxxxxxx" //TODO: Device ID of SECONDO device (R2 luce Luce Cucina Isola)
#define luce_botola "5d1468xxxxxxxxxxxxxxxxxx" //TODO: Device ID of TERZO device (R3 Luce Botola)
#define luce_corridoio "5d1468xxxxxxxxxxxxxxxx" //TODO: Device ID of QUARTO device (R4 Luce Corridoio)
const int relayPin1 = 5; // TODO: Change according to your board
const int relayPin2 = 4; // TODO: Change according to your board
const int relayPin3 = 14; // TODO: Change according to your board
const int relayPin4 = 12; // TODO: Change according to your board
// deviceId is the ID assgined to your smart-home-device in sinric.com dashboard. Copy it from dashboard and paste it here
void turnOn(String deviceId) {
if (deviceId == "5d139xxxxxxxxxxxxxxxxxxx") // ID luce salotto
Serial.print("Turn on device id: ");
Serial.println(deviceId);
digitalWrite(relayPin1, LOW); // turn on relay with voltage HIGH
timer.setTimeout(500L, []() { // Tempo funzionamento 0.5 secondi
digitalWrite(relayPin1, HIGH); // Set Pin 5 HIGH
else if (deviceId == "5d14xxxxxxxxxxxxxxxxxxxxx") // ID luce_cucina_isola
digitalWrite(relayPin2, LOW); // turn on relay with voltage HIGH
digitalWrite(relayPin2, HIGH); // Set Pin 5 HIGH
else if (deviceId == "5d14684xxxxxxxxxxxxxxxxxxxx") // ID luce_botola
digitalWrite(relayPin3, LOW); // turn on relay with voltage HIGH
digitalWrite(relayPin3, HIGH); // Set Pin 5 HIGH
else if (deviceId == "5d146xxxxxxxxxxxxxxxxxxx") // ID luce_corridoio
digitalWrite(relayPin4, LOW); // turn on relay with voltage HIGH
else {
Serial.print("Turn on for unknown device id: ");
void turnOff(String deviceId) {
if (deviceId == "5d139fdxxxxxxxxxxxxxxxxxxxxxxxxx") // ID luce salotto
Serial.print("Turn off Device ID: ");
digitalWrite(relayPin1, HIGH); // turn off relay with voltage LOW
digitalWrite(relayPin1, LOW); // Set Pin 5 HIGH
else if (deviceId == "5d14xxxxxxxxxxxxxxxxxxxxxxxxxxxx") // ID luce_cucina_isola
Serial.println(relayPin2);
digitalWrite(relayPin2, HIGH); // turn off relay with voltage LOW
digitalWrite(relayPin2, LOW); // Set Pin 5 HIGH
else if (deviceId == "5d146xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx") // ID luce_botola
Serial.println(relayPin3);
digitalWrite(relayPin3, HIGH); // turn off relay with voltage LOW
digitalWrite(relayPin3, LOW); // Set Pin 5 HIGH
else if (deviceId == "5dxxxxxxxxxxxxxxxxxxxxxxxxxxxxx) // ID luce_corridoio
Serial.println(relayPin4);
digitalWrite(relayPin4, HIGH); // turn off relay with voltage LOW
digitalWrite(relayPin4, LOW); // Set Pin 5 HIGH
else {
Serial.print("Turn off for unknown device id: ");
void webSocketEvent(WStype_t type, uint8_t * payload, size_t length) {
switch(type) {
case WStype_DISCONNECTED:
Serial.printf("[WSc] Webservice disconnected from sinric.com!\n");
break;
case WStype_CONNECTED: {
isConnected = true;
Serial.printf("[WSc] Service connected to sinric.com at url: %s\n", payload);
Serial.printf("Waiting for commands from sinric.com ...\n");
break;
case WStype_TEXT: {
Serial.printf("[WSc] get text: %s\n", payload);
// Example payloads
// For Switch or Light device types
// {"deviceId": xxxx, "action": "setPowerState", value: "ON"} // https://developer.amazon.com/docs/device-apis/alexa-powercontroller.html
// For Light device type
// Look at the light example in github
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject((char*)payload);
String deviceId = json ["deviceId"];
String action = json ["action"];
if(action == "setPowerState") { // Switch or Light
String value = json ["value"];
if(value == "ON") {
turnOn(deviceId);
turnOff(deviceId);
else if (action == "test") {
Serial.println("[WSc] received test command from sinric.com");
break;
case WStype_BIN:
Serial.printf("[WSc] get binary length: %u\n", length);
break;
#define R1 5 //D1(PIN NODEMCU) = V1 (PIN VIRTUALE)= RELE' IN 1
#define R2 4 //D2(PIN NODEMCU) = V2 (PIN VIRTUALE)= RELE' IN 2
#define R3 14 //D5(PIN NODEMCU) = V3 (PIN VIRTUALE)= RELE' IN 3
#define R4 12 //D6(PIN NODEMCU) = V4 (PIN VIRTUALE)= RELE' IN 4
char auth[] = "bca78xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"; //nodemcu test
char ssid[] = "xxxxxxxxxxxx";
char pass[] = "xxxxxxxxxxxxxx";
//test web http://139.59.206.133/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/update/V1?value=1
//ifttt Esempio: http://139.59.206.133/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxupdate/V1
//Method: PUT
//Content Type: application/json
//Body: ["1"]
//INIZIO PROGRAMMAZIONE PER IFTTT GOOGLE
BLYNK_WRITE(V1)
int value = param.asInt(); // Get value as integer
if (value == 1) //VALORE CHE INTERPRETA
digitalWrite(R1, LOW); // (D1 NODEMCU) GPIO 5 LOW (LUCE SOGGIORNO RELE IN1)
digitalWrite(R1, HIGH); // Set Pin 5 HIGH
Blynk.virtualWrite(V1, HIGH);// Set Virtual Pin 0 HIGH
}); // FINE FUNZIONE TIMER GOOGLE
BLYNK_WRITE(V2)
digitalWrite(R2, LOW); // (D2 NODEMCU) GPIO 4 LOW (LUCE ISOLA RELE IN2)
digitalWrite(R2, HIGH); // Set Pin 4 HIGH
Blynk.virtualWrite(V2, HIGH);// Set Virtual Pin 2 HIGH
BLYNK_WRITE(V3)
digitalWrite(R3, LOW); // (D5 NODEMCU) is GPIO 14 (LUCE BOTOLA RELE IN3)
digitalWrite(R3, HIGH); // Set Pin 14 HIGH
Blynk.virtualWrite(V3, HIGH);// Set Virtual Pin 3 HIGH
BLYNK_WRITE(V4)
digitalWrite(R4, LOW); // (D6 NODEMCU) is GPIO 13 (LUCE CORRIDOIO RELE IN4)
digitalWrite(R4, HIGH); // Set Pin 13 HIGH
Blynk.virtualWrite(V4, HIGH);// Set Virtual Pin 4 HIGH
//FINE PROGRAMMAZIONE PER IFTTT GOOGLE
//CODICE SINRIC
pinMode(relayPin1, OUTPUT);
pinMode(relayPin2, OUTPUT);
pinMode(relayPin3, OUTPUT);
pinMode(relayPin4, OUTPUT);
WiFiMulti.addAP(MySSID, MyWifiPassword);
Serial.println();
Serial.print("Connecting to Wifi: ");
Serial.println(MySSID);
// Waiting for Wifi connect
while(WiFiMulti.run() != WL_CONNECTED) {
delay(500);
Serial.print(".");
if(WiFiMulti.run() == WL_CONNECTED) {
Serial.println("");
Serial.print("WiFi connected. ");
Serial.print("IP address: ");
// server address, port and URL
webSocket.begin("iot.sinric.com", 80, "/");
// event handler
webSocket.onEvent(webSocketEvent);
webSocket.setAuthorization("apikey", MyApiKey);
// try again every 5000ms if connection has failed
webSocket.setReconnectInterval(5000); // If you see 'class WebSocketsClient' has no member named 'setReconnectInterval' error update arduinoWebSockets
//CODICE SINRIC
pinMode(R1, OUTPUT); //D1 is GPIO 5 (..........RELE' IN1) (RELAY BUTTON)
digitalWrite(R1, HIGH); // Set GPIO 5 HIGH
pinMode(R2, OUTPUT); //D2 is GPIO 4 (..........RELE' IN2) (RELAY BUTTON)
digitalWrite(R2, HIGH); // Set GPIO 4 HIGH
pinMode(R3, OUTPUT); //D5 is GPIO 14 (..........RELE' IN3) (RELAY BUTTON)
digitalWrite(R3, HIGH); // Set GPIO 14 HIGH
pinMode(R4, OUTPUT); //D6 is GPIO 12 (..........RELE' IN4) (RELAY BUTTON)
digitalWrite(R4, HIGH); // Set GPIO 12 HIGH
WiFi.begin(ssid, pass); //per aggiornamenti OTA
Blynk.config(auth); //per aggiornamenti OTA
Blynk.connect();; //per aggiornamenti OTA
ArduinoOTA.setHostname("NodeMCU_LUCI_ZONA_GIORNO"); // per aggiornamenti OTA (nome identificativo dispositivo)
ArduinoOTA.begin(); //per aggiornamenti OTA
ArduinoOTA.handle(); //per aggiornamenti OTA
//CODICE SINRIC
webSocket.loop();
if(isConnected) {
uint64_t now = millis();
// Send heartbeat in order to avoid disconnections during ISP resetting IPs over night. Thanks @MacSass
if((now - heartbeatTimestamp) > HEARTBEAT_INTERVAL) {
heartbeatTimestamp = now;
webSocket.sendTXT("H");
//CODICE SINRIC
