Good morning!!! Is it possible to connect blynk with Arduino’s shield gsm? No http_api. If you have a sample sketch ???
Thank you!!!
Thank you!!!
It should work, but you may have to experiment with it to figure out all the required libraries.
You didn’t mention the Arduino type, but here is one of the few available options in the Sketch Builder for an UNO with a GSM Modem. Try them all until you find what works.
Thanks for your answer! I use an Arduino UNO as a board. The sketch builder uses SIM900, SIM800 or M590. Can Tiny libraries do well in my case too? Thank you
I don’t know, just try them.
I also found this, but you probaly already know about it.
sorry for disturbing. You could tell me if these shields are compatible, before spending more money unnecessarily:
or
Grazie!!!
