#define BLYNK_TEMPLATE_ID "TMPL2D7eBhvPS"
#define BLYNK_TEMPLATE_NAME "Science Project Plant watering"
#define BLYNK_AUTH_TOKEN "fqXN2W1Mk-PpCtCv5j9PYEfDxiikytGz"
#define WIFI_SSID
#define WIFI_PASS
#define BLYNK_PRINT SwSerial
#include <LiquidCrystal_I2C.h> // Include the LiquidCrystal I2C library for the LCD
LiquidCrystal_I2C lcd(0x27, 16, 2);
const int moistureSensorPin = A0;
const int waterPumpPin = 9; // Pin for the water pump
const int fertilizerPumpPin = 6; // Pin for the fertilizer pump
int threshold = 500; // Adjust the moisture threshold as needed
bool Relay = 0;
SwSerial.begin(9600);
lcd.init();
lcd.backlight();
Blynk.begin(BLYNK_AUTH_TOKEN,WIFI_SSID,WIFI_PASS);
pinMode(waterPumpPin, OUTPUT);
pinMode(fertilizerPumpPin, OUTPUT);
timer.setInterval(3600000L, readMoisture); // Read moisture every hour
timer.setInterval(86400000L, fertilize); // Fertilize every 24 hours (adjust timing)
BLYNK_WRITE(V0) {
int waterPumpControl = param.asInt();
if (waterPumpControl == 1) {
turnOnWaterPump();
turnOffWaterPump();
BLYNK_WRITE(V2) {
int fertilizerPumpControl = param.asInt();
if (fertilizerPumpControl == 1) {
turnOnFertilizerPump();
turnOffFertilizerPump();
void readMoisture() {
int moistureValue = analogRead(moistureSensorPin);
// Send the moisture value to Blynk
Blynk.virtualWrite(V1, moistureValue);
if (moistureValue < threshold) {
lcd.setCursor(0, 1);
lcd.print("Thirsty");
turnOnWaterPump();
lcd.print("Im Full");
turnOffWaterPump();
void fertilize() {
turnOnFertilizerPump(); // Implement your fertilization logic here
lcd.print("Fertilizing...");
turnOffFertilizerPump(); // Turn off pumps and update LCD
lcd.print("Fertilized: Yes");
void turnOnWaterPump() {
digitalWrite(waterPumpPin, HIGH);
void turnOffWaterPump() {
digitalWrite(waterPumpPin, LOW);
void turnOnFertilizerPump() {
digitalWrite(fertilizerPumpPin, HIGH);
void turnOffFertilizerPump() {
digitalWrite(fertilizerPumpPin, LOW);
and im receiving a Compilation error: no matching function for call to 'BlynkStream::begin(const char [33], const char [18], const char [15])'
@Lasy Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Ok ,no problemi is this better
This isn’t an appropriate Blynk.Begin command when using the SimpleStream library.
Take a look at the Arduino/ESP-01 examplifor how to do it correctly.
char auth[] = "fqXN2W1Mk-PpCtCv5j9PYEfDxiikytGz";
char ssid[] = "Victoria's iphone";
char pass[] = "Wifipassword45";
bool Relay = 0;
lcd.init();
lcd.backlight();
Blynk.begin(auth);
BLYNK_WRITE(V0) {
turnOnWaterPump();
turnOffWaterPump();
BLYNK_WRITE(V2) {
turnOnWaterPump();
turnOffWaterPump();
void fertilize() {
I’m still receiving the same error is this still the wrong format?
Yes.
What’s the format in the example you looked at?
One from the sketch builder
- Blynk IoT app (download from App Store or Google Play)
- Arduino Uno board
example.
/* Fill-in information from Blynk Device Info here */
#define BLYNK_TEMPLATE_ID "TMPxxxxxx"
#define BLYNK_TEMPLATE_NAME "Device"
#define BLYNK_AUTH_TOKEN "YourAuthToken"
SwSerial.begin(115200);
Blynk.begin(Serial, BLYNK_AUTH_TOKEN);
// to avoid delay() function!
Exactly!
Look at the difference in the Blynk.begin command.
Oh!!
Thank you so much.
