i had those lying around so i tried to use them, but cant figure it out
i want the relays off when the wemos d1 mini is powered and then every1 second to power them one by one (think larson scanner but slow and stay ON)
i tried the relay shield it works then i started adding other pins 1-8 but now they are all on and just blink
(boot all ON, relay 1 off on; relay 2 off-on, and so on)
i read to use virtual pins here but cant find how.
i would appreciate if someone could point me in the right direction?
can wemos d1 mini control 8 relay in 2 modules? if not i will order one 8 relay module
thnx alot
blynk is the best (i monitor server temp&humidity at work)
ok so i got i partially working
it works first time after upload after that reset/kill power doesnt work just 2 relays stay on (D3 & D8) should i set these to LOW at boot?
* Relay Shield - Blink
* Turns on the relay for two seconds, then off for two seconds, repeatedly.
* Relay Shield transistor closes relay when D1 is HIGH
const int relayPinD1 = D1;
const long interval = 1000; // pause for two seconds
const int relayPinD2 = D2;
const int relayPinD3 = D3;
const int relayPinD4 = D4;
const int relayPinD5 = D5;
const int relayPinD6 = D6;
const int relayPinD7 = D7;
const int relayPinD8 = D8;
pinMode(relayPinD1, OUTPUT);
pinMode(relayPinD2, OUTPUT);
pinMode(relayPinD3, OUTPUT);
pinMode(relayPinD4, OUTPUT);
pinMode(relayPinD5, OUTPUT);
pinMode(relayPinD6, OUTPUT);
pinMode(relayPinD7, OUTPUT);
pinMode(relayPinD8, OUTPUT);
digitalWrite(relayPinD1, HIGH);
digitalWrite(relayPinD2, HIGH);
digitalWrite(relayPinD3, HIGH);
digitalWrite(relayPinD4, HIGH);
digitalWrite(relayPinD5, HIGH);
digitalWrite(relayPinD6, HIGH);
digitalWrite(relayPinD7, HIGH);
digitalWrite(relayPinD8, HIGH);
digitalWrite(relayPinD1, HIGH); // turn on relay with voltage HIGH
delay(interval); // pause
digitalWrite(relayPinD1, LOW); // turn off relay with voltage LOW
delay(interval);
digitalWrite(relayPinD2, HIGH); // turn on relay with voltage HIGH
delay(interval);
digitalWrite(relayPinD2, LOW); // turn off relay with voltage LOW
delay(interval);
digitalWrite(relayPinD3, HIGH); // turn on relay with voltage HIGH
delay(interval);
digitalWrite(relayPinD3, LOW); // turn off relay with voltage LOW
delay(interval);
digitalWrite(relayPinD4, HIGH); // turn on relay with voltage HIGH
delay(interval);
digitalWrite(relayPinD4, LOW); // turn off relay with voltage LOW
delay(interval);
digitalWrite(relayPinD5, HIGH); // turn on relay with voltage HIGH
delay(interval);
digitalWrite(relayPinD5, LOW); // turn off relay with voltage LOW
delay(interval);
digitalWrite(relayPinD6, HIGH); // turn on relay with voltage HIGH
delay(interval);
digitalWrite(relayPinD6, LOW); // turn off relay with voltage LOW
delay(interval);
digitalWrite(relayPinD7, HIGH); // turn on relay with voltage HIGH
delay(interval);
digitalWrite(relayPinD7, LOW); // turn off relay with voltage LOW
delay(interval);
digitalWrite(relayPinD8, HIGH); // turn on relay with voltage HIGH
delay(interval);
digitalWrite(relayPinD8, LOW); // turn off relay with voltage LOW
delay(interval);// pause
thnx alot, back to google i guess to find out more about virtual pins and a workaround with this issue
Are you using Blynk to achieve your goal?? 16 seconds delay in total at the loop will KILL Blynk… RIP
i will have it connected to ac light switch (via 220v to 5v adapter)
thats why i want it at boot all relays OFF then slowly powering all it can be shorter time 0,5 sec each
and
with blynk i want to have individual control (8 buttons to turn them ON/OFF)
how should i achieve all this? if its doable
BlynkTimer
Virtual Pins and a little if else() logic code tied in with the timers
any example you could help me get started? i would be very thankful, coding is not my strong side
thnx for all the help
You will need to learn enough to get by
I did, am, will still be years from now…
I made this simple example months ago… Coded for Local Server and only 4 relays, so you will need to make those adjustments at least. I haven’t gotten around to posting it on my Example Topic yet, but here it is:
/***************** Library ESP and Blynk *****************/
char auth[] = "xxxxxxxxxx";
char ssid[] = "xxxxxxxxxx";
char pass[] = "xxxxxxxxxx";
char server[] = "xxx.xxx.xxx.xxx";
int port = 8080;
int count;
int ON = 0;
int OFF = 1;
// Set virtual LEDS to these vPins... but these commands are not required since using direct virtualWrite() commands
//WidgetLED led1(V3);
//WidgetLED led2(V4);
//WidgetLED led3(V5);
//WidgetLED led4(V6);
/*************** Array of Relays *********************/
int relay[] = {5, 4, 14, 12}; // The relay pin order for triggering based on count (GPIO pins, NOT using Dpin labeling)
/*************** Setup *********************/
WiFi.begin(ssid, pass);
Blynk.config(auth, server, port);
Blynk.connect();
// Set all array pinmodes and set LOW
for (count = 0; count <= 3; count++) {
pinMode(relay[count], OUTPUT);
digitalWrite(relay[count], OFF);
/*************** Forward pattern *********************/
BLYNK_WRITE(V1) { // Button-Switch Widget
if (param.asInt() == 1) {
for (count = 0; count < 4; count++) { // Count forward
//Serial.print(count);
Blynk.virtualWrite(count+3, 255); // Virtual LED ON (EG count 0 + 3 = V3)
digitalWrite(relay[count], ON); // Toggle relays ON, based on array and count order
Blynk.virtualWrite(count+3, 0); // Virtual LED OFF
digitalWrite(relay[count], OFF); // Toggle relays OFF
Blynk.syncVirtual(V1); // Repeat if switch still ON
else { // Stop all relays if switch OFF
/*************** Backward pattern *********************/
BLYNK_WRITE(V2) { // Button-Switch Widget
if (param.asInt() == 1) { // Count backward
for (count = 3; count >= 0; count--) {
Blynk.syncVirtual(V2);
/*************** Loop *********************/
thnx a ton, i will try as soon as i can, that means in a couple of weeks
will post if i get it working
char auth[] = “waYy74WVVFV1aF2SIh7-kkuXxlQUZmHs”;
char ssid[] = “AndroidAPmin”;
char pass[] = “qwert12345”;
/char server[] = “xxx.xxx.xxx.xxx”;/
/int port = 8080/
int count;
int ON = 0;
int OFF = 1;
// Set virtual LEDS to these vPins… but these commands are not required since using direct virtualWrite() commands
// WidgetLED led1(V3);
// WidgetLED led2(V4);
// WidgetLED led3(V5);
// WidgetLED led4(V6);
/*************** Setup *******************/
// WiFi.begin( ssid, pass);
/ Blynk.config(auth, server, port);/
Blynk.connect();
for (count = 3; count >= 0; count–) {
