Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code.
Code should be formatted as example below.
Hello, I am one of the students who uses Blynk in other countries. I’m making a parking lot using lot now, and I’ve completed what Blynk app led indicates through lr sensor. By the way, is it possible to count the number of led with lcd width on Blynk app? I’d like some examples or help. I’ll attach the code. Thank you, respectful people.
