I have written up my project at:
https://cabin-layout.mixmox.com/2019/01/room-lighting-with-remotesign.html
In addition to a Blynk interface I also added direct API calls using my RemoteSign API
where is your sketch ? ![]()
well, the code is contained in 7 different files. The library implementing the RemoteSign is published with a sample sketch at:
https://remotesign.mixmox.com/p/esp8266-sample-sketch.html
I do not want to publish the parts that handle OTA updates as it includes the URL structure I use on a public server and the rest is rather plain vanilla stuff.
yes but this place is to share the code, not just the ideas
we are just happy for you
Ideas are better than nothing, and yes, some code is a bit too proprietary to benefit others without extensive modification, so not worth posting.
But it is nice to see some of the details and pictures actually posted here, instead of just links. That is better for a sense of forum community integration as opposed to just treating this as a redirection bulletin board.
well enjoyβ¦
//#include "ESP8266WiFi.h"
#include "RemoteSign.h"
#include "Ceiling.h"
#include "utils.h" // auth code, wifi password etc...
#include "Blynkhelper.h"
#include <ESP8266HTTPClient.h>
#include <ESP8266httpUpdate.h>
#include "ota.h"
// hardware setup -----------------------------------------------------
// D0 (built-in) used to show RemoteSign connection
const byte WARM = 4; // D2 Ceiling warm whites
const byte COOL = 5; // D1 Ceiling cool whites
const byte MOUNTAINS = 12; // D6
const byte HIDDEN = 13; // D7
const byte BUTTON = 14; // D5 pushbutton to toggle hidden area
const int DEFAULT_BRI = 800; // 800/1023
RemoteSign rs; //create an instance of RemoteSign
int duration = 0 ; // duration of phone app transitions
int coolBrightness = DEFAULT_BRI; // keep cool brightness value for lightning routine
void BlynkVWriteByte_helper(uint8_t pin, uint8_t value) {
Blynk.virtualWrite(pin, value);
if (pin = V2) {coolBrightness = value;} // keep for lightning
void BlynkVWriteStr_helper(uint8_t pin, char const *pchar) {
Blynk.virtualWrite(pin, pchar);
void lightning(){
Serial.println(F("Lightning"));
int d = random(10,50) ; // delay
analogWrite(COOL, 1023);
delay(d);
analogWrite(COOL, 0);
delay(d);
yield;
delay(d);
delay(d);
delay(d);
analogWrite(COOL, map(coolBrightness,0,100,0,1023)); //put old value back
void executeEvent(int channel,String param) {
//Serial.print(F("Execute event: "));Serial.println(channel);
//Serial.print(F("Params: "));Serial.println(param);
switch (channel) {
case 5: {// lightning
lightning();
break;
} // case 5
default: {
Serial.print(F("Unhandled event on channel: "));Serial.println(channel);
return;
} // switch
} // executeEvent
void displayLabel(int V,int value, int duration){ // V == 0 will do all (for when duration is zero)
String toUse;
switch (V) {
case 0: {
displayLabel(V1,value,duration); // call ourselves thrice
displayLabel(V2,value,duration);
displayLabel(V3,value,duration);
return;
case V1 : {if (duration == 0) {toUse = "Warm";} else{toUse = "Warm -> " + String(value);}; break; }
case V2 : {if (duration == 0) {toUse = "Cool";} else{toUse = "Cool -> " + String(value);}; break; }
case V3 : {if (duration == 0) {toUse = "π";} else{toUse = "π -> " + String(value);}; break; }
Blynk.setProperty(V, "label", toUse);
BLYNK_WRITE(V0) // all on/off button
int value = (param.asInt() ==0) ? 0 : 100; // Get value as integer
//Serial.print("V0"); Serial.print(" now "); Serial.println(value);
rs.LM(1,value,duration);
Blynk.virtualWrite(V1,value);
rs.LM(2,value,duration);
Blynk.virtualWrite(V2,value);
rs.LM(3,value,duration);
Blynk.virtualWrite(V3,value);
rs.LM(4,value == 0 ? LOW:HIGH ,0 );
Blynk.virtualWrite(V4,value == 0 ? LOW:HIGH);
BLYNK_WRITE(V10) { // duration widget
duration = param.asInt(); // keep value in global var
displayLabel(duration,duration,duration); //all zero
void presets(int preset) // presets
int value[4]; // 0 to 3
switch (preset) {
case 21 : { value[1] = 10; value[2]=10;value[3]=70; break; } //sunset
case 22 : { value[1] = 70; value[2]=80;value[3]=0; break; } //cloudy
case 23 : { value[1] = 100; value[2]=100;value[3]=0; break; } // sunny
case 24 : { value[1] = 0; value[2]=0;value[3]=30; break; } // night
case 25 : { value[1] = 0; value[2]=10;value[3]=20; break; } // moonlight
case 26 : { value[1] = 100; value[2]=100;value[3]=20; break; } // all on
case 27 : { value[1] = 0; value[2]=0;value[3]=0; break; } // all off
rs.LM(1,value[1],duration);
rs.LM(2,value[2],duration); coolBrightness = value[2];
rs.LM(3,value[3],duration);
if (duration==0) {
Blynk.virtualWrite(V1,value[1]);
Blynk.virtualWrite(V2,value[2]);
Blynk.virtualWrite(V3,value[3]);
displayLabel(V1,value[1],duration);
displayLabel(V2,value[21],duration);
displayLabel(V3,value[3],duration);
BLYNK_WRITE(V30) { // update button pressed
if (param.asInt() == 1) {
Blynk.setProperty(V30,"label",F("Checking"));
checkForUpdates(); // won't return if there is an update attempt
showversion();
BLYNK_WRITE(V31) { // Network status
int ask = param.asInt() ; // assigning incoming value
if (ask == 1) {
long rssi = WiFi.RSSI();
Blynk.setProperty(V31,"offLabel","πΆ " + String(rssi) + "dBm");
} // V3
BLYNK_WRITE_DEFAULT() { // V1 - V3 sliders for channels 1 - 3 and V4 button for ch 4
int pin = request.pin;
int value = param.asInt();
//Serial.print("V");Serial.print(pin);Serial.print(" now "); Serial.println(value);
// V pins match the channels in this project
switch (pin) {
// light sliders
case 1 :
case 2 :
case 3 : {
rs.LM(pin,value,duration);
displayLabel(pin,value,duration);
if (pin = V2) {coolBrightness = map(value,0,100,0,1023);} // keep cool brightness for lightning
break;
case 4 : {
rs.LM(pin,value == 0 ? LOW:HIGH,0);
break;
// presets
case 21 :
case 22 :
case 23 :
case 24 :
case 25 :
case 26 :
case 27 :
presets(pin);
break;
// events
case 40 : // lightning flash
lightning();
break;
} // switch
} // default catch all
void checkButton(){
static int laststate = HIGH; // pin is using PULLUP
int state = digitalRead(BUTTON);
if (state == laststate) { return;} // no change
// it changed
if (state==LOW) { // it went LOW indicating it was pressed
rs.LM(4,-1,0); // toggle ch 4
laststate=state;
void showversion(){
Blynk.setProperty(V30,"label","Ver " + String(FW_VERSION));
// switch a string of lights to DEFAULT_BRI right away
pinMode(WARM, OUTPUT); analogWrite(WARM, DEFAULT_BRI);
//Serial.begin(115200);
// get onto wifi
// method #1
//WiFiConnect(ssid, password); // non-Blynk
// method #2
//WiFi.begin(ssid, pass); // Non-blocking if no WiFi available
//Blynk.config(auth, server, port);
//Blynk.connect();
// method #3
Blynk.begin(auth, ssid, password); // get onto wifi network with Blynk
printWifiStatus();
// switch second string of lights to DEFAULT_BRI after connecting
pinMode(COOL, OUTPUT); analogWrite(COOL, DEFAULT_BRI);
// show version of firmware
showversion();
// set up pushbutton pin
pinMode(BUTTON,INPUT_PULLUP);
// set the app duration slider to zero
Blynk.virtualWrite(V10,duration);
// set up RemoteSign
rs.setFirmwareVersion("Ceiling " + String(FW_VERSION));
// define channel data
rs.setChannelData(1, 'M', WARM, true, "warm"); // 3.5 Amps draw
rs.setChannelData(2, 'M', COOL, true, "cool"); // 5 Amps draw
rs.setChannelData(3, 'M', MOUNTAINS, true, "mountains"); // 2.7 Amps draw
rs.setChannelData(4, 'M', HIDDEN, false, "hidden area"); // ~ 3 Amps draw
rs.setChannelData(5, 'E', "Lightning");
// map virtual pins to channels
rs.setBlynkPin(1, 1);
rs.setBlynkPin(2, 2);
rs.setBlynkPin(3, 3);
rs.setBlynkPin(4, 4);
// set some default values
// todo
rs.begin(); // start server listening
} // setup
rs.run();
checkButton();
} // loop()
and utils.h
//utils
#ifndef utils_h
#define utils_h
String getMAC() {
uint8_t mac[6];
const byte len = 18; //length of MAC address string
char result[len];
WiFi.macAddress(mac);
// I use - instead of : so that the MAC address can be used in URI
snprintf(result, len, "%02x-%02x-%02x-%02x-%02x-%02x", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
// ucase the hex values
for(int i = 0; i<len; i++) {
result[i] = toupper(result[i]);
return String(result);
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print(F("\nπ SSID: "));
Serial.print(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print(F(" π§ IP: "));
Serial.print(ip);
Serial.print(F(" MAC: "));
Serial.print(getMAC());
// print the received signal strength:
Serial.print(F(" πΆ "));
Serial.print(rssi);
Serial.println(F("dBm"));
void WiFiConnect(char const* ssid, char const* password) {
WiFi.begin(ssid, password);
Serial.print(ssid);
delay(250);
Serial.print(F("β³"));
printWifiStatus();
#endif // #ifndef utils
