He conectado algunos sensores a Blynk y quisiera saber como puedo descargar los datos obtenidos por los sensores?
Before creating the topic
  1. Search forum for similar topics
  2. Check http://docs.blynk.cc and http://help.blynk.cc/
  3. Add details :
    • Blynk Library version
    • Add your sketch code. :point_up:Code should be formatted as example below.
Please edit your topic with short title and clear questions and details in the body of the post.
Also… look at SuperChart
