I’m working on a multi-sensor unit using ESP 8266 and HC-SR501 PIR sensor, along w other sensors. All sensors working fine except the HC-SR501 PIR sensor. I’m not getting any reading in Blynk. Tried both “push” and other seconds in Blynk and also tried the 2 adjustment screws. Also tried 3 other HC-SR501 PIR sensor units but my guess is it’s in the code somewhere. Code is below minus person info. Thank you all!
#include <DHT.h>
/************************* Pin Definition *********************************/
//Relays for switching appliances
#define Relay1 D6
#define Relay2 D2
#define Relay3 D1
#define Relay4 D5
//DHT11 for reading temperature and humidity value
#define DHTPIN D7
//buzzer to use it for alert
#define buzzer D0
//Selection pins for multiplexer module to switch between different sensors and give data on a single analog pin.
#define S0 D3
#define S1 D4
//Analog pin to read the incoming analog value from different sensors.
#define analogpin A0
int proximity;
int light;
int gas;
int motion;
char auth[] = "Blynk_Token";
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
char ssid[] = "SSID";
char pass[] = "PASS";
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V0, t);
Blynk.virtualWrite(V1, h);
Blynk.virtualWrite(V2, proximity);
Blynk.virtualWrite(V3, gas);
Blynk.virtualWrite(V4, motion);
Blynk.virtualWrite(V5, light);
dht.begin();
pinMode(S0, OUTPUT);
pinMode(S1, OUTPUT);
pinMode(A0, INPUT);
pinMode(buzzer, OUTPUT);
// Now we can publish stuff!
// Address 00
digitalWrite(S0, LOW);
digitalWrite(S1, LOW);
gas = analogRead(analogpin);
Serial.print("Gas - "); Serial.println(gas);
// Address 10
digitalWrite(S0, HIGH);
motion = analogRead(analogpin);
if (motion > 512)
motion = 1;
motion = 0;
// Address 01
digitalWrite(S1, HIGH);
proximity = analogRead(analogpin);
Serial.print("Proximity - "); Serial.println(proximity);
if (proximity < 512)
proximity = 1;
digitalWrite(buzzer, HIGH);
proximity = 0;
digitalWrite(buzzer, LOW);
// Address 11
int raw_light = analogRead(analogpin);
light = map(raw_light, 1024, 0, 0, 100);
Serial.print("Light - "); Serial.println(light);
