Hc-05 + Blink (Multiple Problems)
I am currently trying to control 3 servo’s which have different functions. So, currently im trying to read joystick values, but multiple problems arise.
  1. Random And Frequent Login Timeouts
  2. Package Too Big
    Although increasing write interval of hc 05 alleviates the problem a little bit. And the frequency of login timeout’s decreases.
    And yes i have also removing redundancy of (including and creating its instance 2 times) software serial library and nothing changes.
    Board Used: Arduino Uno + Hc-05
    Android Version: 8.0.0
    EMUI Version: 8.0.0
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  Note: This only works on Android!
        iOS does not support Bluetooth 2.0 Serial Port Profile
        You may need to pair the module with your smartphone
        via Bluetooth settings. Default pairing password is 1234
  NOTE: Bluetooth support is in beta!
  You can receive x and y coords for joystick movement within App.
  App project setup:
    Two Axis Joystick on V1 in MERGE output mode.
    MERGE mode means device will receive both x and y within 1 message
SoftwareSerial SwSerial(5,6); // RX, TX
char auth[] = "LB5f9pbvaFos2sY4zwCqh_1YcGFpT24B";
SoftwareSerial SerialBLE(5,6); // RX, TX
#include <Servo.h>
Servo myservoKICKER;
Servo myservoLEFTWHEEL;
Servo myservoRIGHTWHEEL;
int pos;
BLYNK_WRITE(V1) {
  int xAxis =param[0].asInt();
  int yAxis= param[1].asInt();
  Serial.print("X = ");
  Serial.print(xAxis);
  Serial.print("Y = ");
  Serial.println(yAxis);
  if (xAxis > 400 && xAxis < 600 && yAxis > 400 && yAxis < 600)
          myservoLEFTWHEEL.detach();
          myservoRIGHTWHEEL.detach();
          myservoKICKER.detach();
      // FORWARDS FAST
      if (xAxis > 400 && xAxis < 600 && yAxis > 1018 && yAxis <= 1023)
          myservoLEFTWHEEL.attach(9);
          myservoRIGHTWHEEL.attach(10);
          myservoLEFTWHEEL.write (180);
          myservoRIGHTWHEEL.write (0);
      // BACKWARDS FAST
      if (xAxis > 400 && xAxis < 600 && yAxis >= 0 && yAxis < 5)
          myservoLEFTWHEEL.write (0);
          myservoRIGHTWHEEL.write (180);
      // LEFT FAST
      if (xAxis >= 0 && xAxis < 5 && yAxis > 400 && yAxis < 600)
      // RIGHT FAST
      if (xAxis > 1018 && xAxis <= 1023 && yAxis > 400 && yAxis < 600)
      // FORWARDS MEDIUM
      if (xAxis > 400 && xAxis < 600 && yAxis > 750 && yAxis < 1018)
          myservoLEFTWHEEL.write (110);
          myservoRIGHTWHEEL.write (70);
      // BACKWARDS MEDIUM
      if (xAxis > 400 && xAxis < 600 && yAxis > 5 && yAxis < 250)
          myservoLEFTWHEEL.write (70);
          myservoRIGHTWHEEL.write (110);
      // LEFT MEDIUM
      if (xAxis > 5 && xAxis < 250 && yAxis > 400 && yAxis < 600)
      // RIGHT MEDIUM
      if (xAxis > 750 && xAxis < 1018 && yAxis > 400 && yAxis < 600)
      // FORWARDS SLOW
      if (xAxis > 400 && xAxis < 600 && yAxis > 600 && yAxis < 750)
          myservoLEFTWHEEL.write (100);
          myservoRIGHTWHEEL.write (80);
      // BACKWARDS SLOW
      if (xAxis > 400 && xAxis < 600 && yAxis > 250 && yAxis < 400)
          myservoLEFTWHEEL.write (80);
          myservoRIGHTWHEEL.write (100);
      // LEFT SLOW
      if (xAxis > 250 && xAxis < 400 && yAxis > 400 && yAxis < 600)
          myservoRIGHTWHEEL.attach(9);
      // RIGHT SLOW
      if (xAxis > 600 && xAxis < 750 && yAxis > 400 && yAxis < 600)
          myservoLEFTWHEEL.attach(10);
      //  FORWARDS LEFT FAST
      if (xAxis >= 0 && xAxis < 5 && yAxis > 1018 && yAxis <= 1023)
          myservoLEFTWHEEL.write (115);
      // FORWARDS RIGHT FAST
      if (xAxis > 1018 && xAxis <= 1023 && yAxis > 1018 && yAxis <= 1023)
          myservoRIGHTWHEEL.write (65);
      // BACKWARDS LEFT FAST
      if (xAxis >= 0 && xAxis < 5 && yAxis >= 0 && yAxis < 5)
          myservoLEFTWHEEL.write (65);
      // BACKWARDS RIGHT FAST
      if (xAxis > 1018 && xAxis <= 1023 && yAxis >= 0 && yAxis < 5)
          myservoRIGHTWHEEL.write (115);
      //  FORWARDS LEFT MEDIUM
      if (xAxis > 5 && xAxis < 400 && yAxis > 600 && yAxis < 1018)
          myservoLEFTWHEEL.write (105);
      // FORWARDS RIGHT MEDIUM
      if (xAxis > 600 && xAxis < 1018 && yAxis > 600 && yAxis < 1018)
          myservoRIGHTWHEEL.write (75);
      // BACKWARDS LEFT MEDIUM
      if (xAxis > 5 && xAxis < 400 && yAxis > 5 && yAxis < 400)
          myservoLEFTWHEEL.write (75);
      // BACKWARDS RIGHT MEDIUM
      if (xAxis > 600 && xAxis < 1018 && yAxis > 5 && yAxis < 400)
          myservoRIGHTWHEEL.write (105);
BLYNK_WRITE(V2){ // Fast Kicker Pin
  int FastKick= param.asInt();
  Serial.print(FastKick);
  if(FastKick == 1)
          myservoKICKER.attach(11);
          delay(100);
          myservoKICKER.write (90);
          delay(200);
          myservoKICKER.write (160);
          delay(200);
BLYNK_WRITE(V3){ //Slow Kicker Pin
  int SlowKick=param.asInt();
  if(SlowKick == 1)
          delay(100);
          for (pos = 160; pos >= 90; pos -= 1)
              myservoKICKER.write (pos);
              delay(5);
          delay(200);
BLYNK_WRITE(V4){ //WHEEL CALIBRATION
  int WheelCalibration=param.asInt();
  if(WheelCalibration == 1)
          myservoLEFTWHEEL.attach(2);
          myservoRIGHTWHEEL.attach(3);
          delay(100);
          myservoLEFTWHEEL.write (90);
          myservoRIGHTWHEEL.write (90);
          delay(30000);
BLYNK_WRITE(V5){ //KICKER 90 DEGREE CALIBRATION
  int KickerCalibration= param.asInt();
  if(KickerCalibration == 1)
          delay(100);
          delay(200);
  myservoLEFTWHEEL.attach(9);   //1
  myservoRIGHTWHEEL.attach(10);  //2
  myservoKICKER.attach(11);   //3
  // detach servos to avoid jitter on power up
  SerialBLE.begin(9600);
  Blynk.begin(SerialBLE, auth);
This is how the errors are shown
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
//_, /////_
__/ v0.6.1 on Arduino Uno
[89] Connecting…
[3229] Login timeout
[5229] Connecting…
[8349] Login timeout
[10349] Connecting…
[13469] Login timeout
[15469] Connecting…
[20589] Connecting…
X = 519Y = 517
X = 512Y = 512
X = 519Y = 516
X = 40Y = 0
[21199] Packet too big: 14647
[25709] Connecting…
[25950] Packet too big: 12544
[30829] Connecting…
[35949] Connecting…
X = 688Y = 1011
[36072] Ready (ping: 1ms).
X = 395Y = 1023
X = 98Y = 668
[36355] Invalid HW cmd: v
Waiting for connections…
[44408] Connecting…
[47528] Login timeout
[49528] Connecting…
[52648] Login timeout
[54648] Connecting…
[57768] Login timeout
[59768] Connecting…
[62888] Login timeout
[64888] Connecting…
[68008] Login timeout
[70008] Connecting…
[73128] Login timeout
[75128] Connecting…
[78248] Login timeout
[80248] Connecting…
[83368] Login timeout
[85368] Connecting…
[88488] Login timeout
[90488] Connecting…
[93608] Login timeout
[95608] Connecting…
[98728] Login timeout
[100728] Connecting…
[103848] Login timeout
[105848] Connecting…
[108968] Login timeout
[110968] Connecting…
X = 508Y = 519
X = 0Y = 532
X = 91Y = 835
[114089] Login timeout
[116089] Connecting…
X = 512Y = 512
X = 1006Y = 528
X = 385Y = 0
X = 512Y = 0
[116358] Packet too big: 2304
[121210] Connecting…
[124331] Login timeout
[126331] Connecting…
I have just realised, the login timeout and other problems are due to huge number of commands added in BLYNK_WRITE(V1).
Is there anyway i can do the comparisons outside the scope?
