Software and Hardware Used: I am using Arduino Uno and Python for Web Development.
Problem: I am new to IoT so I tried using Blynk to control LED connected to Arduino through the mobile app. I was successful. What I now want is - to have a simple button in HTML which turns on my LED connected to the Arduino to Port - D13 via USB. I want this to be done locally without any cloud if possible.
I tried using the API but wasn’t successful.
did you install local server ?
Yes, But I need the code to run the API (for python). I am doing something wrong there.
I think it is the same for any language
IP server:port /xxxxxxxxxxxxxxxxxxxxxx authtoken/update/V85?value=low // LED off
IP server:port /xxxxxxxxxxxxxxxxxxxxxx authtoken/update/V85?value=high // LED on
where V85 is a led or something else
Okay, and V85 is virtual port (for example) and what about Digital Port (say D13)? I am completely new, sorry for lame question.
You have to attach D13 to Vpin LED with if ( … )
C++
IP server:port /xxxxxxxxxxxxxxxxxxxxxx authtoken/update/V83?value=low // LED off
IP server:port /xxxxxxxxxxxxxxxxxxxxxx authtoken/update/V83?value=high // LED on
where V83 is a led or something else
BLYNK_WRITE(V83){ // virtual LED
int Value = param.asInt();
if (Value == HIGH) {
digitalWrite(D13, HIGH);
digitalWrite(D13, LOW);
Make sure “low” and “high” aren’t sent as strings, otherwise,
param.asInt();
will always return 0.
value is not a string else you have to write “low”
I guess it depends on how you invoke the URL. From the Windows DOS prompt using HTTPie and from the Blynk HTTP RESTful API, low in the context of update/V83?value=low is a string.
I invoke the URL from the web, I have no problem by my side.
it was an example for @Aniket_Dogra
Thank you everyone. I took another path and didn’t use API. Wrote a python script directly to the ports using PySerial. Thank You @Blynk_Coeur for your help
Just FYI … you can write directly to the ports using the API as well.
