Thanks, Pavel for your response. If I wanted to attempt to get Blynk working with a rn-xv. Where would you recommend I start or should I wait for this module to be supported - I realize you all have a lot going on right now.
Yes, I started integration of RN-XV WiFly, but yes I left it unfinished due to other tasks.
Drop me an email to volodymyr@blynk.cc, and I will send you example sketch and explain what I have already done.
Thanks!
As for our latest thread i suggest you should also add: Arduino Duemilanove.
I’t working on the UNO setting, as @vshymanskyy suggested.
Maybe a : Arduino Duemilanove (set as: Uno not as Due !) remark has to be added to.
Greeting from The Netherlands,
RadioRon.
Any estimated date of arival for this arduino modem module?
esp8266 as modem is my dream. Any estimation time?
Any concrete dates on getting support for the SeeedStudio Ethernet Shield? I was really sad when I saw it wasn’t supported because I just bought it today.
@epicman57,
Just added support for this in the master branch (not released yet). Could you check it?
Hi all,
In the beta version (master branch on github) I added support for:
- ESP8266 as Arduino WiFi modem (running original firmware)
- SeeedStudio Ethernet Shield V2.0 (W5200)
Please test them and give your feedback to volodymyr@blynk.cc
Thanks.
Hello, I’m trying to compile example for esp8266
but got this error
Arduino: 1.6.4 (Mac OS X), Плата"Arduino Uno"
sketch_jun11b:40: error: no matching function for call to 'ESP8266::ESP8266(SoftwareSerial&)'
sketch_jun11b.ino:40:22: note: candidates are:
In file included from sketch_jun11b.ino:35:0:
/Users/artem/Projects/arduino/libraries/ITEADLIB_Arduino_WeeESP8266-master/ESP8266.h:70:5: note: ESP8266::ESP8266(HardwareSerial&)
ESP8266(HardwareSerial &uart);
/Users/artem/Projects/arduino/libraries/ITEADLIB_Arduino_WeeESP8266-master/ESP8266.h:70:5: note: no known conversion for argument 1 from 'SoftwareSerial' to 'HardwareSerial&'
/Users/artem/Projects/arduino/libraries/ITEADLIB_Arduino_WeeESP8266-master/ESP8266.h:45:7: note: ESP8266::ESP8266(const ESP8266&)
class ESP8266 {
/Users/artem/Projects/arduino/libraries/ITEADLIB_Arduino_WeeESP8266-master/ESP8266.h:45:7: note: no known conversion for argument 1 from 'SoftwareSerial' to 'const ESP8266&'
how can I fix it? Thanks
@asci,
It seems you’re not reading carefully the comments in the sketch…
You need to modify the library header file to select if you want to use Software Serial.
what do i want to modify if i only want to try the simplest application?
i connected an arduino uno to an esp8266 and i just want to light LED 13 using a button.
I’d like to report that I was just able to get Blynk 0.2.2 working with my ethernet-based TI Tiva C Connected Launchpad (EK-TM4C1294XL), Energia 15, and my iPhone with very little modification. I did need to move a couple of lines of Print.h from private to public to get things to compile (commenting out the destructor in WidgetConsole.h also “works” too). However, I’m not sure I know the best way to handle this issue so that Blynk would work out of the box for this board.
It would be great to see support for all of TI’s Connected LaunchPads via Energia.
@horchler Great news! I’d love to hear more like this
I removed the destructor of WidgetConsole (it was useless).
Please try using the latest version (master branch) and post if it works for you.
Thanks for contributing!
@vhymanskyy: Thank you. Just tried the updated master branch. Works great with my LaunchPad without any code modifications. I’m currently using “Generic Board”, but it would be great to see TI’s boards added to the list in the iOS/Android apps.
Does Blynk Support standalone AVR chips like ATMEGA 16 , 16A and the same? I wish to implement standalone projets with the chip; instead of using Arduino . Thank you for this great app.
Yes, I think you can.
You will have to understand how to use in with Arduino IDE. Something like this should help: http://openhardware.ro/using-atmega16-with-arduino-ide/
Serial Blynk connection type should work (it works even on ATtiny85!!!).
For other connection types - you may need to write more code.
