Dear Blynk Community.
I have been setting up ESP8266 / Arduino Uno / iPhone 5S / Blynk-Cloud to help automate my greenhouse. My temp and tank volume sensors are all working well on Blynk, but the 4Ch relay is not actuating reliably from the App, particularly when using timer. Without ‘mission critical’ timer actuation, I can’t rely on Blynk to do the job… but would very much like to enact some ‘fail safe’ coding to self check the App state to the Physical State.
My problem with the Relays staying in physical sync with the App button. I find that perhaps around one in five times, the App button does not actuate the relay even if it shows “ON” in the App. The Blynk send “HIGH” to the digital pin D5 gets lost somewhere, and the app is not detecting if its picked up on the physical level and actuated (there appears to be no feedback back to the app from the physical state).
This is most apparent when using the timer widget to actuate the relay via Button( D5 ) : it may sometimes actuate properly but when it comes to turn off (ie send LOW or 0), the App button actuates, but the message does not reliably get through to the Physical State of the relay (via ESP8266 and Arduino) (and vice versa)
As part of my testing, I added a VirtualPin7 to indicate the physical state back on the app :
Blynk.virtualWrite(7, digitalRead(5)); // writes PHYSICAL pin state back to Blynk to cross check
I have also tried the “Hardware State Sync from App” code to no avail.
I am using timers properly with no delays in the void loop() (well best I can)!
I am wondering if any code legends out there can think up a way to detect a state mis-match on the App side between my (D5 button) and the (V7 Physical State of D5 button)?
MANY THANKS!
Please excuse the beginners code and the likely many errors!
/* Sketch using ESP8266 as software serial modem, wifi enabling Arduino
* 30Nov18 : added BLYNK functionality
* 30Nov18 : added analogue TEMP function (36GZ)
* 2 Dec18 : added first (T0) digital TEMP function (DS18B20)
* 2 Dec18 : added second (T1) digital TEMP on same oneWire bus
* 2 Dec18 : added 4ch relay via Blynk.
* 7 Dec18 : added DHT22 temp humidity sensor (digital) to pin A0 (see TempDHT22 sketch)
* 13Dec18 : added Volume calc, altered dist pins to A0 / A1. DHT22 to pin A2
* 13Dec18 : added Blynk.notify for low tank alarm
* 14Dec18 : added Averaging for DISTANCE (no good.. clears array to zero each reset)
* 14Dec18 : added Blynk Timer, and Blynk.synchall()
#include <DHT.h>;
#include <ESP8266_Lib.h>
#include <OneWire.h> // OneWire Bus for Digital Temp Gauge
#include <DallasTemperature.h> // Digital TEMP Gauge support
// BLYNK wireless setup (Blynk runs the ESP8266)
char auth[] = "XXXXXXX"; // BLYNK token
char ssid[] = "XXXXXXX";
char pass[] = "XXXXXX";
int pinV7;
float humDHT01; // stores first DHT22 humidity value
float tempDHT01; // stores first DHT22 temp values
float volume;
float temp1; //
float temp2; //
void myTimerEvent(){
Blynk.virtualWrite(2, temp1); // sends temp1 to Blynk virtual pin 2
Blynk.virtualWrite(3, temp2); // sends temp2 to Blynk virtual pin 3
Blynk.virtualWrite(4, tempDHT01); // sends tempDHT01 to Blynk virtual pin 4
Blynk.virtualWrite(5, humDHT01); // sends humDHT01 to Blynk virtual pin 5
Blynk.virtualWrite(1, volume); // sends volume to Blynk Virtual Pin 1
Blynk.virtualWrite(6, digitalRead(11)); // writes PHYSICAL pin state back to Blynk to cross check
Blynk.virtualWrite(8, digitalRead(6)); // writes PHYSICAL pin state back to Blynk to cross check
Blynk.virtualWrite(9, digitalRead(7)); // writes PHYSICAL pin state back to Blynk to cross check
Blynk.virtualWrite(10, digitalRead(8)); // writes PHYSICAL pin state back to Blynk to cross check
// Averaging Setup
const int numReadings = 10; // size of array to average over
int readings[numReadings]; // declares the array
int readIndex = 0; // variable 0 to 49 to be used to read / write array bucket position
float total = 0; // running total variable - starts at 0
float average = 0; // average variable - starts at 0
int thisReading = 0; // declares the reading position counter variable
// Keep this flag not to re-sync on every reconnection
bool isFirstConnect = true;
// This function will run every time Blynk connection is established
BLYNK_CONNECTED() {
if (isFirstConnect) {
// Request Blynk server to re-send latest values for all pins
Blynk.syncAll();
// You can also update individual virtual pins like this:
//Blynk.syncVirtual(V0, V2);
isFirstConnect = false;
BLYNK_WRITE(V7)
pinV7 = param.asInt(); // assigning incoming value from pin V7 to a variable
// process received value
SoftwareSerial EspSerial(2, 3); // RX, TX : sets up an instance of SoftwareSerial called EspSerial
#define ESP8266_BAUD 9600 // Your ESP8266 baud rate (note no ";" after #define!!)
#define ONE_WIRE_BUS 4 // oneWire bus on PIN 4 (note no ";" after #define!!)
// DHT22 temperature setup :
#define DHTPIN A2
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE); // call an instance of the DHT sensor
int chk;
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS); // Setup OneWire Instance
// Pass the oneWire reference to Dallas Temperature
ESP8266 wifi(&EspSerial); // not sure what this does
//Distance : sensor sketch using code from Altronics Z6322 product data sheet tutorial
const int trig = A0;
const int echo = A1;
long time, dist; // declare the variables being used in Distance calculations
const int reedPin = A3;
#define RELAY1 5
#define RELAY2 6
#define RELAY3 7
#define RELAY4 8
#define BLYNK_MAX_READBYTES 1024
// --------------SETUP------SETUP-------------------SETUP------------------SETUP------------SETUP--------------
// TIMER Setup to be called
timer.setInterval(5000L, myTimerEvent);
//not sure if need to set pinMode or if Blynk does that
pinMode(RELAY1, OUTPUT);
pinMode(RELAY2, OUTPUT);
pinMode(RELAY3, OUTPUT);
pinMode(RELAY4, OUTPUT);
pinMode(reedPin, INPUT_PULLUP); // sets A3 HIGH, so closing REED sends it LOW.
Serial.begin(9600); // allows you to see what is going on to DEBUG if necessary
sensors.begin(); // Start up the Dallas Temp library
dht.begin(); // Start up the DHT22 library
// Distance : set the pinmodes
pinMode(trig, OUTPUT); // note OUTPUT must be in CAPS
pinMode(echo, INPUT); // note INPUT must be in CAPS
Blynk.begin(auth, wifi, ssid, pass,"45.55.96.146",80);
// -----------------------LOOP ------------------------- LOOP-------------LOOP ------------
sensors.requestTemperatures(); // Send the command to get temperature readings
temp1 = sensors.getTempCByIndex(0); // gets the temp reading one oneWire index 0, ie temp1
temp2 = sensors.getTempCByIndex(1); // gets the temp reading two oneWire index 1, ie temp2
tempDHT01=dht.readTemperature(); // gets the DHT22 temperature reading
humDHT01=dht.readHumidity(); // gets the DHT22 humidity reading
// ULTRASONIC DISTANCE SENSOR & VOLUME section : writing to Virtual Pin 1
digitalWrite(trig, LOW); // ensure the trig is LOW for a clean HIGH pulse
delayMicroseconds(2);
digitalWrite(trig, HIGH);
delayMicroseconds(10); //PING triggered by HIGH pulse of more then 2 micro seconds
time = pulseIn(echo, HIGH); // returns HIGH pulse length (microseconds) at pin 'echo'
dist = 906 - ((time/2)/2.91); // converts the time into a distance in mm, 2.91 microsec per mm
volume = (dist * dist * 0.0001659) + (dist * 0.2496272);
if (volume <= 100) Blynk.notify("Hydroponic Tank level had dropped below 100L"); // ALARM NOTIFY
// ----- END LOOP ---------- END LOOP -------------- END LOOP ------------------
