@PeteKnight I only have this pin assignment, nothing more alas.
Which version of arduino IDE do you use to compile?
So, are you saying that you’ve successfully reverse engineered the code controls the CD4051 multiplexer and can control these peripherals with your existing code?
@PeteKnight well I bought that interface, together with the sketch for the Nano and the sketch works with remotexy, so far I have reverse engineered. So If I can make a sketch that controlls the Nano, as the bought sketch does (from wich the source was posted in this topic) but with MQTT, Node-red or something I can controll from within Domoticz, that would be the solution I am looking for,
The seller of the card gave me the Pin assignment sheet.
this is the remotexy code that works:
/*// -- Jacuzzi -- // version 6 avec
gestion améliorée des états invalides des leds
yield() function pour éviter les freeze (enfin je pense que cela y contribue)
Pour Jacuzzi SSP-H-20.1 Bubble only
R6.2.1 : avec fonction delay sur lecture segment et suppression clignotement
// RemoteXY include library //
// RemoteXY select connection mode and include library
#define REMOTEXY_MODE__ESP8266_SOFTSERIAL_CLOUD
// activate debug output on Serial 115200; ESP on SW Serial
#define REMOTEXY__DEBUGLOGS Serial
#include <RemoteXY.h>
// RemoteXY connection settings
#define REMOTEXY_SERIAL_RX 3
#define REMOTEXY_SERIAL_TX 2
#define REMOTEXY_SERIAL_SPEED 9600
#define REMOTEXY_WIFI_SSID "<<SSID>>"
#define REMOTEXY_WIFI_PASSWORD "<PASS>>"
#define REMOTEXY_CLOUD_SERVER "cloud.remotexy.com"
#define REMOTEXY_CLOUD_PORT 6376
#define REMOTEXY_CLOUD_TOKEN "<<TOKEN>>" // MO Jacuzzi token
// "THE REMOTE XY TOKEN See www.remotexy.com/en/account/tokens/"
// RemoteXY App configuration
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] =
{ 255,5,0,25,0,217,0,8,8,1,
130,2,5,4,53,19,46,129,0,2,
39,12,5,16,70,105,108,116,101,114,
0,65,38,30,27,6,6,129,0,2,
27,15,5,1,79,110,47,79,102,102,
0,129,0,2,51,15,5,16,72,101,
97,116,101,114,0,1,1,23,27,6,
6,29,94,79,0,1,1,23,39,6,
6,29,94,79,0,1,1,23,51,6,
6,29,94,79,0,129,0,39,32,7,
5,16,85,112,0,129,0,39,45,13,
5,16,68,111,119,110,0,1,1,53,
31,7,7,29,94,79,0,1,1,53,
44,7,7,29,94,79,0,65,38,30,
39,6,6,65,38,30,51,6,6,67,
0,11,4,13,18,35,26,2,67,0,
22,4,10,18,35,26,2,67,0,30,
4,12,18,35,26,2,67,2,40,9,
8,11,35,26,2,129,0,9,68,45,
8,191,87,97,116,101,114,32,116,101,
109,112,46,0,67,1,18,78,17,10,
2,26,11,129,0,36,79,8,8,2,
194,176,99,0,129,0,54,99,6,3,
17,82,54,46,50,0 };
// this structure defines all the variables of the control interface for the RemoteXY App
struct {
// input variable
uint8_t bpPower; // =1 if button pressed, else =0
uint8_t bpFilter; // =1 if button pressed, else =0
uint8_t bpHeater; // =1 if button pressed, else =0
uint8_t bpUp; // =1 if button pressed, else =0
uint8_t bpDown; // =1 if button pressed, else =0
// output variable
uint8_t ledPower_r; // =0..255 LED Red brightness
uint8_t ledPower_g; // =0..255 LED Green brightness
uint8_t ledFilter_r; // =0..255 LED Red brightness
uint8_t ledFilter_g; // =0..255 LED Green brightness
uint8_t ledHeater_r; // =0..255 LED Red brightness
uint8_t ledHeater_g; // =0..255 LED Green brightness
char digit1[2]; // string UTF8 end zero
char digit2[2]; // string UTF8 end zero
char digit3[2]; // string UTF8 end zero
char digit4[2]; // string UTF8 end zero
char waterTemp[11]; // string UTF8 end zero
// other variable
uint8_t connect_flag; // =1 if wire connected, else =0
RemoteXY;
#pragma pack(pop)
// END RemoteXY include //
// define I/O
#define SEGA 8 // actif LOW : état segment a également jetLed
#define SEGB 16 // actif LOW : état segment b également heater2Led
#define SEGC 17 // actif LOW : état segment c également sunheatPos
#define SEGD 9 // actif LOW : état segment d également set1Led
#define SEGE 10 // actif LOW : état segment e également filterLed
#define SEGF 11 // actif LOW : état segment f également heater1Led
#define SEGG 7 // actif LOW : état segment g
#define SEGDP 12 // actif LOW : état segment dp également set2Led
#define AFF1 A4 // actif LOW : Données afficheur digit 1 disponibles
#define AFF2 A1 // actif LOW : Données afficheur digit 2 disponibles
#define AFF3 A0 // actif LOW : Données afficheur digit 3 disponibles
#define AFF4 A5 // actif LOW : Données afficheur digit 4 disponibles
#define LEDS 13 // actif LOW : Données des autres LED's disponibles
#define LEDPOWER A7 // lecture d'un état on/off via Analog input car plus de digital input disponible
#define C4051 4 // D4 D5 et D6 utilisées en OUTPUT pour codage de 7 Commandes (+ 1 état neutre)...
#define B4051 5 // ....via 3 sorties et multiplexeur-interrupteur analogique CD4051
#define A4051 6 // CD4051 : C = pin 9; B= pin 10; A = pin 11
// déclaration des valeurs lues sur les I/O
boolean a,b,c,d,e,f,g,dp,h; // lecture de l'état des segments digits
boolean cdeAff1,cdeAff2,cdeAff3,cdeAff4,cdeLeds; // lecture du digit pour lequel les infos sont transmises
int powerLed; //lecture valeur analogique
boolean heater1Led,heater2Led,filterLed,jetLed; //bubbleLed non utilisée par manque d'entrées sur Nano
// déclaration et initialisation de variables
char digit[2];
int adigit=0,adigit1=0,adigit2=0,adigit3=0;
String digitseg="";
String digitsegled="11111111";
float tempWater=20.0;
int delayReadSeg=15;
// déclaration divers compteurs
int i=0;
int j=0;
int k1=0;
int k2=0;
int l=0;
int m=0;
int n=0;
int o=0;
int p=0;
int q=0;
int r=0;
int s=0;
int imax=1000; // nombre max d'itérations de lecture des bits de données afficheurs et états leds
int jmax=5; // autre compteur de base utilisé à divers endroits
// To replace the delay function (lets other routines working)
unsigned long currentMillis ;
unsigned long previousMillis1 = 0;
unsigned long previousMillis2 = 0;
unsigned long previousMillis3 = 0;
unsigned long previousMillis4 = 0;
const long interval1 = 250; // interval at which to repeat (delay in milliseconds)
const long interval2 = 5000;
const long interval3 = 10000;
const long interval4 = 20000;
RemoteXY_Init ();
// 115200 mendatory for debug
analogReference(INTERNAL);
// affectation des modes aux I/O Arduino; (pas de déclaration pour les entrées analogiques car pas d'alternative)
pinMode(SEGA,INPUT); // voir également les autres affectations de ces entrées dans la fonction Void lecture digit ci-dessous
pinMode(SEGB,INPUT);
pinMode(SEGC,INPUT);
pinMode(SEGD,INPUT);
pinMode(SEGE,INPUT);
pinMode(SEGF,INPUT);
pinMode(SEGG,INPUT);
pinMode(SEGDP,INPUT);
pinMode(AFF1,INPUT);
pinMode(AFF2,INPUT);
pinMode(AFF3,INPUT);
pinMode(AFF4,INPUT);
pinMode(LEDS,INPUT);
// No need to define A7 (powerLed) because INPUT only
pinMode(C4051,OUTPUT); // 3 Sorties vers CD 4051 positionnées à 1
pinMode(B4051,OUTPUT);
pinMode(A4051,OUTPUT);
digitalWrite(C4051,1);
digitalWrite(B4051,1);
digitalWrite(A4051,1);
// initialisation des variables à la valeur 1 car le circuit fonctionne en logique inversée
a=1,b=1,c=1,d=1,e=1,f=1,g=1,dp=1;
cdeAff1=1,cdeAff2=1,cdeAff3=1,cdeAff4=1,cdeLeds=1;
powerLed=1023;
heater1Led=1,heater2Led=1,filterLed=1;
// affichage par défaut au lancement
RemoteXY.ledPower_r=0;RemoteXY.ledPower_g=0;
RemoteXY.ledHeater_r=0;RemoteXY.ledHeater_g=0;
RemoteXY.ledFilter_r=0;RemoteXY.ledFilter_g=0;
digit[0]='0';
strcpy (RemoteXY.digit1, digit);
strcpy (RemoteXY.digit2, digit);
strcpy (RemoteXY.digit3, digit);
digit[0]='c';
strcpy (RemoteXY.digit4, digit);
dtostrf(tempWater, 0, 0, RemoteXY.waterTemp);
RemoteXY_Handler();
// acquisition des valeurs introduites via l'app : delais de lecture des segments après flanc descendant
// du bit de données afficheurs ou led's et nombre max d'itérations de lecture de ces bits
// gestion des commandes en provenance RemoteXY via BCD vers 1 de 10 (en réalité 1 de 8) (Mux analogique CD4051)
// gestion de la durée de l'impulsion de commande
currentMillis = millis();
if (currentMillis - previousMillis1 >= interval1) {
previousMillis1 = currentMillis;
if(RemoteXY.bpFilter!=0) {
digitalWrite(C4051,0);
digitalWrite(B4051,0);
digitalWrite(A4051,0); }
if(RemoteXY.bpUp!=0) {
previousMillis4 = millis(); // to freeze the update of tempWater when pushed
digitalWrite(A4051,1); }
if(RemoteXY.bpDown!=0) {
if(RemoteXY.bpPower!=0) {
if(RemoteXY.bpHeater!=0) {
lectureleds();
// lecture et décodage des digits
i=0;
cdeAff1=digitalRead(AFF1);
while (cdeAff1==1 && i<imax) {cdeAff1=digitalRead(AFF1);i++;yield();}
if (cdeAff1==0 && i<imax) {
delayMicroseconds(delayReadSeg);
lecturedigit();
decodage();
if (digit[0] != 'x' && digit[0] != 'c' && digit[0] != ' ') {
adigit1=adigit;
strcpy (RemoteXY.digit1, digit);}
i=0;
cdeAff2=digitalRead(AFF2);
while (cdeAff2==1 && i<imax) {cdeAff2=digitalRead(AFF2);i++;yield();}
if (cdeAff2==0 && i<imax) {
lecturedigit();
decodage();
if (digit[0] != 'x' && digit[0] != 'c' && ((millis() - previousMillis4) <= (interval4/4)) ) { // ' ' value authorized when modifying temp instruction
adigit2=adigit;
strcpy (RemoteXY.digit2, digit);}
adigit2=adigit;
i=0;
cdeAff3=digitalRead(AFF3);
while (cdeAff3==1 && i<imax) {cdeAff3=digitalRead(AFF3);i++;yield();}
if (cdeAff3==0 && i<imax) {
lecturedigit();
decodage();
adigit3=adigit;
strcpy (RemoteXY.digit3, digit);}
adigit3=adigit;
i=0;
cdeAff4=digitalRead(AFF4);
while (cdeAff4==1 && i<imax ) {cdeAff4=digitalRead(AFF4);i++;yield();}
if (cdeAff4==0 && i<imax) {
lecturedigit();
decodage();
if (digit[0] != 'x' && digit[0] != ' ') {
strcpy (RemoteXY.digit4, digit);}
// affichage température de l'eau jacuzzi moyennant respect des conditions
if (digit[0]=='c' && adigit1==0 && (currentMillis - previousMillis4) >= interval4) {
// previousMillis4=currentMillis;
tempWater=(adigit3+(10*adigit2));
// si l'afficheur sur SPA est en °F, conversion en °c (tempSun et tempWater tjrs en °c)
if (digit[0]=='F' && (currentMillis - previousMillis4) >= interval4) {
tempWater=((adigit3+(10*adigit2)+(100*adigit1)-32)/1.8);
void lectureleds(){
// tests delay usec: de 10 à 200: c'est 15 usec qui donne mes meilleurs résultats (99% de réussite)
// détection platine sous tension (=> Led Rouge allumée) + lecture et décodage des led's d'état
// jmax changements consécutifs pour être pris en compte
i=0;
cdeLeds=digitalRead(LEDS);
while (cdeLeds==1 && i<imax){cdeLeds=digitalRead(LEDS);i++;yield();} // détection présence de bits états LED
if (cdeLeds==0 && i<imax){
powerLed=analogRead(LEDPOWER); // utilisation d'une entrée analogique pour lecture d'une valeur digitale suite manque d'entrées digitales
lecturedigit();
if(powerLed<=900){a=0;}
else{a=1;}
digitseg=String(String(a)+String(f)+String(b)+String(d)+String(dp)+String(e)+String(c));
s=0;
while(digitsegled!=digitseg && s<jmax){
i=0;s++;yield();
lecturedigit();
else{a=1;}
if(digitsegled!=digitseg){
digitsegled=digitseg;
heater1Led=f;heater2Led=b;filterLed=e;
if(powerLed<=900){RemoteXY.ledPower_r=255;RemoteXY.ledPower_g=0;}
else{RemoteXY.ledPower_r=0;RemoteXY.ledPower_g=0;}
if(heater2Led==0 && heater1Led==1){RemoteXY.ledHeater_r=255;RemoteXY.ledHeater_g=0;} // led rouge
if(heater2Led==1 && heater1Led==0){RemoteXY.ledHeater_r=0;RemoteXY.ledHeater_g=255;} // led verte
if(heater2Led==1 && heater1Led==1){RemoteXY.ledHeater_r=0;RemoteXY.ledHeater_g=0;} // led éteinte
if(filterLed==0){RemoteXY.ledFilter_r=0;RemoteXY.ledFilter_g=255;} // led verte
else{RemoteXY.ledFilter_r=0;RemoteXY.ledFilter_g=0;} // led éteinte
void decodage(){
// Actif LOW
digitseg=String(String(a)+String(b)+String(c)+String(d)+String(e)+String(f)+String(g));
digit[0]='x';
if (digitseg == "1111111") {digit[0]=' ';adigit=0;}
if (digitseg == "0000001") {digit[0]='0';adigit=0;}
if (digitseg == "1111001") {digit[0]='1';adigit=1;}
if (digitseg == "0010010") {digit[0]='2';adigit=2;}
if (digitseg == "0110000") {digit[0]='3';adigit=3;}
if (digitseg == "1101000") {digit[0]='4';adigit=4;}
if (digitseg == "0100100") {digit[0]='5';adigit=5;}
if (digitseg == "0000100") {digit[0]='6';adigit=6;}
if (digitseg == "1110001") {digit[0]='7';adigit=7;}
if (digitseg == "0000000") {digit[0]='8';adigit=8;}
if (digitseg == "0100000") {digit[0]='9';adigit=9;}
if (digitseg == "0000111") {digit[0]='c';adigit=10;}
if (digitseg == "1001000") {digit[0]='H';adigit=11;}
if (digitseg == "0000110") {digit[0]='E';adigit=12;}
if (digitseg == "1000110") {digit[0]='F';adigit=13;}
if (digitseg == "1011100") {digit[0]='n';adigit=14;}
if (digitseg == "0011000") {digit[0]='d';adigit=13;}
// Serial.print(digit[0]);
void lecturedigit(){
a=digitalRead(SEGA); // également jetLed
b=digitalRead(SEGB); // également heater2Led
c=digitalRead(SEGC);
d=digitalRead(SEGD);
e=digitalRead(SEGE); // également filterLed
f=digitalRead(SEGF); // également heater1Led
g=digitalRead(SEGG);
dp=digitalRead(SEGDP);
In that case, I’d work on getting your Nano to connect to MQTT using the ESP-01 as a WiFi modem.
To overcome your compilation error you should first of all reboot your PC then turn-on verbose compilation output in File > Preferences of the Arduino IDE
I did as recommended, the output of the compilation is:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Maiko\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Maiko\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Maiko\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\Maiko\AppData\Local\Temp\arduino_build_373568 -warnings=none -build-cache C:\Users\Maiko\AppData\Local\Temp\arduino_cache_487760 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Maiko\AppData\Local\Temp\arduino_modified_sketch_895268\sketch_may16a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Maiko\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Maiko\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Maiko\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\Maiko\AppData\Local\Temp\arduino_build_373568 -warnings=none -build-cache C:\Users\Maiko\AppData\Local\Temp\arduino_cache_487760 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Maiko\AppData\Local\Temp\arduino_modified_sketch_895268\sketch_may16a.ino
Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\Maiko\\AppData\\Local\\Temp\\arduino_build_373568\\sketch\\sketch_may16a.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for WiFiEsp.h: [WiFiEsp@2.2.2]
ResolveLibrary(WiFiEsp.h)
-> candidates: [WiFiEsp@2.2.2]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\WiFiEsp\\src" "C:\\Users\\Maiko\\AppData\\Local\\Temp\\arduino_build_373568\\sketch\\sketch_may16a.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SoftwareSerial.h: [SoftwareSerial@1.0]
ResolveLibrary(SoftwareSerial.h)
-> candidates: [SoftwareSerial@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\WiFiEsp\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SoftwareSerial\\src" "C:\\Users\\Maiko\\AppData\\Local\\Temp\\arduino_build_373568\\sketch\\sketch_may16a.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for PubSubClient.h: [ESP8266_Microgear@1.2.4]
ResolveLibrary(PubSubClient.h)
-> candidates: [ESP8266_Microgear@1.2.4]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\WiFiEsp\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\ESP8266_Microgear" "C:\\Users\\Maiko\\AppData\\Local\\Temp\\arduino_build_373568\\sketch\\sketch_may16a.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\WiFiEsp\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\ESP8266_Microgear" "C:\\Users\\Maiko\\Documents\\Arduino\\libraries\\WiFiEsp\\src\\WiFiEsp.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\WiFiEsp\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\ESP8266_Microgear" "C:\\Users\\Maiko\\Documents\\Arduino\\libraries\\WiFiEsp\\src\\WiFiEspClient.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\WiFiEsp\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\ESP8266_Microgear" "C:\\Users\\Maiko\\Documents\\Arduino\\libraries\\WiFiEsp\\src\\WiFiEspServer.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\WiFiEsp\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\ESP8266_Microgear" "C:\\Users\\Maiko\\Documents\\Arduino\\libraries\\WiFiEsp\\src\\WiFiEspUdp.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\WiFiEsp\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\ESP8266_Microgear" "C:\\Users\\Maiko\\Documents\\Arduino\\libraries\\WiFiEsp\\src\\utility\\EspDrv.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\WiFiEsp\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\ESP8266_Microgear" "C:\\Users\\Maiko\\Documents\\Arduino\\libraries\\WiFiEsp\\src\\utility\\RingBuffer.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\WiFiEsp\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\ESP8266_Microgear" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SoftwareSerial\\src\\SoftwareSerial.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\WiFiEsp\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\ESP8266_Microgear" "C:\\Users\\Maiko\\Documents\\Arduino\\libraries\\ESP8266_Microgear\\AuthClient.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for ESP8266WiFi.h: [ESP8266WiFi@1.0]
ResolveLibrary(ESP8266WiFi.h)
-> candidates: [ESP8266WiFi@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\WiFiEsp\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Maiko\\Documents\\Arduino\\libraries\\ESP8266_Microgear" "-IC:\\Program Files (x86)\\Arduino\\libraries\\ESP8266WiFi\\src" "C:\\Users\\Maiko\\Documents\\Arduino\\libraries\\ESP8266_Microgear\\AuthClient.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for queue.h: []
ResolveLibrary(queue.h)
-> candidates: []
In file included from C:\Program Files (x86)\Arduino\libraries\ESP8266WiFi\src/ESP8266WiFi.h:33:0,
from C:\Users\Maiko\Documents\Arduino\libraries\ESP8266_Microgear\AuthClient.h:10,
from C:\Users\Maiko\Documents\Arduino\libraries\ESP8266_Microgear\AuthClient.cpp:7:
C:\Program Files (x86)\Arduino\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:26:10: fatal error: queue.h: No such file or directory
#include <queue.h>
compilation terminated.
Using library WiFiEsp at version 2.2.2 in folder: C:\Users\Maiko\Documents\Arduino\libraries\WiFiEsp
Using library SoftwareSerial at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial
Using library ESP8266_Microgear at version 1.2.4 in folder: C:\Users\Maiko\Documents\Arduino\libraries\ESP8266_Microgear
Using library ESP8266WiFi at version 1.0 in folder: C:\Program Files (x86)\Arduino\libraries\ESP8266WiFi
exit status 1
Error compiling for board Arduino Nano.
This shows that you don’t have the PubSubClient library installed. You can install it via the IDE library manager. You want the latest version (2.8.0) by Nick O’Leary (the guy behind Node-Red).
There may be other issues too, but fix this first then try again.
I don’t know what the Adafruit ESP8266 library does, but it won’t be used when compiling code for an Arduino AVR based board.
You were right with the PSclient, I installed and now it compiles, let me investigate it further, thx so far for all your help
