@mikje have you read this:
http://help.blynk.cc/getting-started-library-auth-token-code-examples/blynk-basics/keep-your-void-loop-clean
You already have a timer declared, but you’re only using it for one thing, which is to to send your device uptime to the app.
This is in effect a 250ms interval timer, but done in a less efficient way than BlynkTimer would do it,
You need to be de-cluttering your void loop, not adding to it
You need something with a lot more processing power and much higher clock speed in my opinion.
