Hi. nodemcu can not connect to local server but connect to cloud
the server version is: 0.33.0
android app can successfully register and login to local server on port 9443
the sketch:
#include <DHT.h> //Declarate DHT Library
#include <ESP8266WiFi.h> //Declarate ESP8266 Board Library
#define DHTPIN 4 //Pin of DHT 22
#define DHTTYPE DHT22 //Type of DHT
DHT dht(DHTPIN, DHTTYPE); //Declarate dht
int val = 0; //Declarate val variable
char auth[] = "976f5e30be0c47c2ac50d5b027b03bf0"; //Put your blink token
char ssid[] = "MikroTik Home"; //Put your SSID of your connection
char pass[] = "123456"; //Put your Password of your connection
char server[] = "10.5.51.3";
Blynk.begin(auth, ssid, pass, server); //Connect the blynk to esp8266 board
dht.begin(); //Start DHT sensor
Blynk.run(); //Run the Blynk
float h = dht.readHumidity(); //Read humidity and put it in h variable
float t = dht.readTemperature(); //Read temperature and put it in t variable
float q = analogRead(A0); //Read air quality and put it into q variable
Blynk.virtualWrite(V5, t); //Send t value to blynk in V5 virtual pin
Blynk.virtualWrite(V6, h); //Send h value to blynk in V6 virtual pin
Blynk.virtualWrite(V0, q); //Send q value to blynk in V0 virtual pin
if (q>100) {
Blynk.notify("The Quailty of air is bad !!"); //Blynk will send notify if q>70
if (t>40) {
Blynk.notify("The Temperature is too high"); //Blynk will send notify if t>40
