Was following updates meant for blynk server but couldn’t find any particular like earlier blynk server release for java8 for current 0.41.10 like in earlier release of 0.41.8 had openjdk, kindly guide if the release 0.41.10 run with Java 8…Thanks
@Gunner & @Dmytro Although Java 11 is available for older ARM processors, there are email certificate issues using java versions other than openjdk, but openjdk does’t run on processors below ARM7. I tried multiple releases of Java 10 and 11 on my raspberry pi zero and couldn’t email with any of them.
Is there a fix to the email issue that I’ve missed?
Sorry to hear that… but I have absolutely NO association with Blynk development, so all I can suggest is as already above, upgrade and update, including hardware if needed.
Or somehow figure out how to generate your own Java8 version from the server source code… and sorry, I have no idea how to do that
No complains at all, just notice.
Open software developers have their own targets and priorities.
As you said, if you need something different, you have to take action on your own…
Fair!
