Hello, I am seeking assistance for my smart greenhouse project. I am looking for a way to ensure that the automations continue to function even when the ESP is not connected to Blynk. I have tried various methods such as timers and millis, but have been unsuccessful. I kindly request your help and would greatly appreciate a prompt response as I have a presentation tomorrow XD. Here is my current code:
#include <DHT.h>
char auth[] = "";
char ssid[] = "";
char pass[] = "";
bool Relay1 = 0;
bool Relay2 = 0;
bool Relay3 = 0;
#define moister A0
#define waterPump D6
#define ac D4
#define light D5
#define DHTPIN D2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
void soilMoistureSensor() {
int value = analogRead(moister);
value = map(value, 0, 1023, 0, 100);
value = (value - 100) * -1;
Blynk.virtualWrite(V0, value);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
Serial.println("Falha na leitura do sensor DHT!");
return;
Blynk.virtualWrite(V2, h); //V2 é para Humidade
Blynk.virtualWrite(V3, t); //V3 é para Temperatura
pinMode(waterPump, OUTPUT);
pinMode(ac, OUTPUT);
pinMode(light, OUTPUT);
digitalWrite(waterPump, HIGH);
digitalWrite(ac, HIGH);
digitalWrite(light, HIGH);
Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
timer.setInterval(1000L, soilMoistureSensor);
timer.setInterval(3000L, sendSensor);
BLYNK_WRITE(V1) {
Relay1 = param.asInt();
if (Relay1 == 1) {
digitalWrite(waterPump, LOW);
BLYNK_WRITE(V4) {
Relay2 = param.asInt();
if (Relay2 == 1) {
digitalWrite(ac, LOW);
BLYNK_WRITE(V5) {
Relay3 = param.asInt();
if (Relay3 == 1) {
digitalWrite(light, LOW);
if (WiFi.status() != WL_CONNECTED) { // verifica se não há conexão com a internet
Serial.println("Sem conexão com a internet.");
Blynk.disconnect(); // desconecta do servidor Blynk
WiFi.disconnect(); // desconecta da rede WiFi
delay(1000); // aguarda um segundo
WiFi.begin(ssid, pass); // tenta se conectar novamente à rede WiFi
while (WiFi.status() != WL_CONNECTED) { // aguarda até que haja conexão com a internet
Serial.print(".");
Blynk.connect(); // reconecta ao servidor Blynk
Blynk.run();//Executa a biblioteca Blynk
timer.run();//Executa o timer Blynk
delay(2000);
if (!WiFi.isConnected()) {
// Código para controlar o ar condicionado e a luz caso não haja conexão com a internet
if (t >= 27) {
} else if (t <= 23){
if (t <= 12) {
} else if (t >= 20) {
// Código para controlar a bomba de água caso não haja conexão com a internet
if (value < 10) {
} else if (value > 50) {
