I am not sure if this is new or was reported before? I was working with Android 4.2 and now tested my dashboard with iOS 8.4. On both systems I updated to the latest App. When placing a graph widget and defining the style (e.g. line) this style is inverted in the other OS. Can you reproduce this?
Sorry for not being to specific. I defined a line graph in Android and logged out. Then I logged in on the Android Tab and on the iPad. The Android device shows the line graph correctly and the iPad uses a bar graph := “inverted”:
There may be more than just a syncing issue. All my virtual pins go away as soon as I turn off the app. When the dashboard reloads all vPins are gone. Physical ones seem to work fine.
I’m using an iPad2 and an iPhone 5 now, latest IOS. All pins just disappear as soon as I turn off the app.
Currently not because of the issues I’m having. My android phone has been empty for the past couple days anyway, lol.
-edit
Most other settings stay fine though. I just updated my Android to latest Blynk, just in case, but things like buttons in Switch mode, stay that way. It’s, as far as I can see, only the vPin assignments which go away.
Using Android also makes no difference from what I can tell.
