I am testing simple gps trigger, that turns on relay, when I am in GPS range and it should turn this relay off, when I am out of the range.
At the moment relay is turned on, when I enter the GPS range, but not turned off when I leave range. I have one GPS Trigger in Blynk app on Android phone, assigned to V1 and trigger option is to “Enter”.
Do you have same suggestion, how to trigger relay turn off, when I am leaving the GPS range?
#include <ESP8266_Lib.h>
char auth[] = "123123123123123213123";
char ssid[] = "12121";
char pass[] = "1212";
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
void myTimerEvent()
int relejastavoklis = digitalRead(8);
Blynk.virtualWrite(V6, relejastavoklis);
BLYNK_WRITE(V1) {
int GpsState = param.asInt();
if (GpsState){
Serial.print("ienāca, ieslēdz, gps state:");
Serial.println(GpsState);
digitalWrite(8, LOW);//iesleedz
}else{
Serial.print("izgaja, izslēdz, gps state: ");
digitalWrite(8, HIGH);//izsleedz
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
