GPS Trigger missing HIGH to LOW Output. It has only LOW to HIGH. Of course I could made walk around with virtual pins. But with physical pins I need both directions.
Blynk Legacy stopped being developed over 2 years ago, and is no longer supported, so this issue isn’t going to be fixed.
You either need to live with it and use your workaround, or migrate to Blynk IoT and come to terms with the different way in which location based data is handled in the new system.
