Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code.
Code should be formatted as example below.
- add details
hardware model : Arduino due
smartphone amdroid + blynk leagcy
bylnk server
BlynkSimpleSerialBLE.h
I am working on a gps tracking project, but an error occurs in the GPS Streaming code. I would appreciate it if you could tell me how to solve this problem.
error
error: ‘GpsParam’ was not declared in this scope
error: expected ‘;’ before ‘gps’
error: ‘class TinyGPS’ has no member named ‘getLat’
error: ‘class TinyGPS’ has no member named ‘getLon’
Compilation error: ‘GpsParam’ was not declared in this scope
