iOS 11.2.1
Raspberry Pi Zero
I’m trying to send iPhone gps location to the Raspberry Pi at the moment
import BlynkLib
auth=“(auth token)”
blynk=BlynkLib.Blynk(auth)
@blynk.VIRTUAL_WRITE(2)
def show_location(param):
print(param)
then command
blynk.run()
the result shows the latitude, longitude, altitude and speed like below
(let me hide some numbers for the privacy)
“–.339733”
“—.489085”
“—.474854”
“0.000000”
I have a problem with these inseparable parameters.
originally param[0] is expected to indicate the latitude, and param[1] longitude… but it’s not how the params work.
“param” seems to indicate all of four numbers above, which is so weird
actually
list(param)
returns four each list (in which each digits are listed for some reason) instead of a list containing four the numbers
[“-”,“-”,“.”,“3”,“3”,“9”,“7”…]
[“-”,“-”,“-”,“.”,“4”,“8”,“9”,“0”…]
so how can i get each parameters separately?
