Hello, I used this code a while ago and now I’m trying to use it, but I don’t understand what the problem is. The message appears on the serial no gps detected: check wiring, although the connections are correct and I used it before without problems
#include <TinyGPS++.h>
static const int RXPin = D2, TXPin = D1; // GPIO 4=D2(conneect Tx of GPS) and GPIO 5=D1(Connect Rx of GPS
static const uint32_t GPSBaud = 4800; //if Baud rate 9600 didn't work in your case then use 4800
TinyGPSPlus gps; // The TinyGPS++ object
WidgetMap myMap(V0); // V0 for virtual pin of Map Widget
SoftwareSerial ss(RXPin, TXPin); // The serial connection to the GPS device
float spd; //Variable to store the speed
float sats; //Variable to store no. of satellites response
String bearing; //Variable to store orientation or direction of GPS
char auth[] = "XyUJEU69C_yHLY3wFridLPp8VTGi9dg6"; //Your Project authentication key
char ssid[] = "ULTRA ARDUINO 6"; // Name of your network (HotSpot or Router name)
char pass[] = "qwerty123"; // Corresponding Password
//unsigned int move_index; // moving index, to be used later
unsigned int move_index = 1; // fixed location for now
Serial.println();
ss.begin(GPSBaud);
timer.setInterval(5000L, checkGPS); // every 5s check if GPS is connected, only really needs to be done once
void checkGPS(){
if (gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
Blynk.virtualWrite(V4, "GPS ERROR"); // Value Display widget on V4 if GPS not detected
while (ss.available() > 0)
// sketch displays information every time a new sentence is correctly encoded.
if (gps.encode(ss.read()))
displayInfo();
void displayInfo()
if (gps.location.isValid() )
float latitude = (gps.location.lat()); //Storing the Lat. and Lon.
float longitude = (gps.location.lng());
Serial.print("LAT: ");
Serial.println(latitude, 6); // float to x decimal places
Serial.print("LONG: ");
Serial.println(longitude, 6);
Blynk.virtualWrite(V1, String(latitude, 6));
Blynk.virtualWrite(V2, String(longitude, 6));
myMap.location(move_index, latitude, longitude, "GPS_Location");
spd = gps.speed.kmph(); //get speed
Blynk.virtualWrite(V3, spd);
sats = gps.satellites.value(); //get number of satellites
Blynk.virtualWrite(V4, sats);
bearing = TinyGPSPlus::cardinal(gps.course.value()); // get the direction
Blynk.virtualWrite(V5, bearing);
Serial.println();
