I’ll start with the fact that I’m not a programmer and this is my first project. I’m trying to make a controller for a GrowBox or greenhouse.
At the moment, this code works and the whole project works. But recently there was a problem: from the temperature sensor si7021 stopped receiving temperature data and the heater worked constantly. How to write code to avoid such errors and the heater turned off when incorrect data from the sensor?
Code below, please do not kick I am not a professional.
The project is running on WeMos D1 R2 and uses a local blynk server running on Rpi2
#define SENSOR A0 //подключение датчика влажности
#include <TimeLib.h>
#include <WidgetRTC.h>
#include "Adafruit_Si7021.h"
Adafruit_Si7021 sensor = Adafruit_Si7021();
//#include <Servo.h>
//Servo servo;
// Include the libraries we need
#include <OneWire.h>
#include <Wire.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS D3
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
// Pass our oneWire reference to Dallas Temperature.
// arrays to hold device address
DeviceAddress insideThermometer;
WidgetRTC rtc;
//char auth[] = "";
char auth[] = ""; //test
char ssid[] = "Rt-ru";
char pass[] = "qazwsxedcrfv";
WidgetLED led1(V6); //индикатор обогрева
WidgetLED led2(V9); //индикатор освещения
WidgetLED led3(V8); //индикатор вытяжки
WidgetLED led4(V12); //индикатор испарителя
WidgetLED led5(V21); //индикатор обдува
long startTimeInSecs = 18000;//время включения освещения "Утро", до изменения в приложении
long stopTimeInSecs = 82800;//время выключения освещения "Вечер", до изменения в приложении
long tim; //вычисление текущего времени
//температура включения и выключения отопления по умолчанию
int TempHeatOffDay=33;//температура выключения обогрева днём
int TempHeatOffNight=25;//температура выключения обогрева ночью
int TempHeatOff;
//влажность включения и выключения вытяжки по умолчанию
int humMax;//Влажность максимум
int humMin;//Влажность минимум
//состояние вентиляции
//int servoValue;
int buttonState; //состояние кнопки
int ventState; //состояние вентиляции
float sensorHumidity; //влажность с сенсора
float sensorTemp; //температура с сенсора
int wifisignal; //мощность wifi сигнала
int humGround; //влажность почвы
long startWateringTimeInSecs; //Время начала полива
int TimeWatering; //длительность полива
BLYNK_WRITE(V3) { //ввод температуры дневной, старт обогрева
TempHeatOffDay = param.asInt();
Serial.print("Температура выключения обогрева день: ");
Serial.println(TempHeatOffDay);
BLYNK_WRITE(V4) { //ввод температуры ночной, старт обогрева
TempHeatOffNight = param.asInt();
Serial.print("Температура выключения обогрева ночь: ");
Serial.println(TempHeatOffNight);
BLYNK_WRITE(V7) { //ввод времени старта и окончания освещения
startTimeInSecs = param[0].asLong(); // this would result in startTimeInSecs = 0
stopTimeInSecs = param[1].asLong(); // this would result in endTimeInSecs = 3600
BLYNK_WRITE(V10) { //ввод минимальной влажности
humMin = param.asInt(); // assigning incoming value from pin V1 to a variable
Serial.print("Влажность минимальная: ");
Serial.println(humMin);
if (humMin >= humMax) {
humMax = humMin+10;
Blynk.virtualWrite(V11, humMax);
BLYNK_WRITE(V11) { //ввод максимальной влажности
humMax = param.asInt(); // assigning incoming value from pin V1 to a variable
Serial.print("Влажность максимальная: ");
Serial.println(humMax);
if (humMax <= humMin) {
humMin = humMax-10;
Blynk.virtualWrite(V10, humMin);
BLYNK_WRITE(V15) {
if (param.asInt() == 0) {
digitalWrite(D7, LOW);
Serial.println("Вентиляция выключена");
else {
digitalWrite(D7, HIGH);
Serial.println("вентиляция включена");
BLYNK_WRITE(V20) {
Serial.println("Обдув выключен");
digitalWrite(D4,LOW);
led5.off();
else {
Serial.println("Обдув включен");
digitalWrite(D4,HIGH);
led5.on();
BLYNK_WRITE(V22) { //ввод времени старта и окончания освещения
startWateringTimeInSecs = param[0].asLong(); // this would result in startTimeInSecs = 0
Serial.println(startWateringTimeInSecs);
BLYNK_WRITE(V23) { //ввод максимальной влажности
TimeWatering = param.asInt()* 60; // assigning incoming value from pin V1 to a variable
Serial.println(TimeWatering);
void sendWifi()
wifisignal = map(WiFi.RSSI(), -105, -40, 0, 100);
Blynk.virtualWrite(V16, wifisignal);
void timerWatering() {
long stopWateringTimeInSec = startWateringTimeInSecs + TimeWatering;
if (tim >= startWateringTimeInSecs && tim <= stopWateringTimeInSec){
digitalWrite(D0,HIGH);
Serial.println("полив активирован");
else {
digitalWrite(D0,LOW);
Serial.println("полив выключен");
void timerSvet() {
sensorHumidity = sensor.readHumidity(); //влажность с si7021
Blynk.virtualWrite(V2, sensorHumidity);
tim = (hour() * 3600 + minute() * 60); //вычисляем текущее время в секундах
if (tim >= startTimeInSecs && tim <= stopTimeInSecs) //
digitalWrite(D6,HIGH);
Serial.print("Свет включен");
Serial.println();
led2.on();
TempHeatOff=TempHeatOffDay;
//испаритель включается и выключается только в дневное время
if (sensorHumidity < humMin) {
digitalWrite(D8,HIGH); //включение испарителя
Serial.print("испаритель вкл");
Serial.println();
led4.on();
Blynk.setProperty(V12, "color", "#00979D");
if (sensorHumidity > humMax) {
digitalWrite(D8,LOW); //выключение испарителя
Serial.print("испаритель выкл");
Serial.println();
led4.on();
Blynk.setProperty(V12, "color", "#D3435C");
else {
digitalWrite(D6,LOW);
Serial.println("Свет выключен");
Serial.println("Испаритель выключен");
led2.off();
TempHeatOff=TempHeatOffNight;
digitalWrite(D8,LOW); //выключение испарителя на ночь
void heating()
sensorTemp = sensor.readTemperature(); //температура с si7021
Blynk.virtualWrite(V1, sensorTemp);
if (sensorTemp > TempHeatOff)
digitalWrite(D5,LOW);
Serial.println("Обогрев выключен");
Serial.println(TempHeatOff);
led1.off();
else {
digitalWrite(D5,HIGH);
Serial.print("Обогрев включен");
led1.on();
void tempVnesh() {
sensors.requestTemperatures(); // запрос температуры с 18d20
float tempC = sensors.getTempCByIndex(0); // запрос температуры с 18d20
Blynk.virtualWrite(V0, tempC);
void water() {
uint16_t sensor = analogRead(SENSOR);
humGround = map(sensor, 630, 330, 0, 100);
Serial.println("влажность почвы");
Serial.println(humGround);
Blynk.virtualWrite(V18, humGround);
BLYNK_WRITE(V17) // Reset
if (param.asInt()==1) {
timer.setTimeout(2000, reset_esp);
void reset_esp()
delay(3000);
ESP.restart();
delay(5000);
//Blynk.begin(auth, ssid, pass);
Blynk.begin(auth, ssid, pass, "farahome.zzux.com", 8081);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,231), 8080);
//Blynk.begin(auth, ssid, pass, IPAddress(149,154,114,250), 8081);
Blynk.syncAll();
timer.setInterval(1000L, heating);
timer.setInterval(5060L, tempVnesh);
timer.setInterval(5120L, timerSvet);
timer.setInterval(10180L, sendWifi);
timer.setInterval(5240L, water);
timer.setInterval(5300L, timerWatering);
//timer.setInterval(5000L, clockDisplay);
sensor.begin();
pinMode(D0, OUTPUT); //полив
pinMode(D4, OUTPUT); //обдув
pinMode(D5, OUTPUT); //обогрев
pinMode(D6, OUTPUT); //освещение
pinMode(D7, OUTPUT); //вентиляция
pinMode(D8, OUTPUT); //испаритель
led1.off();
led2.off();
led3.off();
led4.off(); //испаритель
led5.off(); //обдув
rtc.begin();
sensors.begin();
//servo.attach(D0);
digitalWrite(D8,HIGH); //начальное включение испарителя
