I am trying to get the example that shows how value can be pushed from Arduino to
the Blynk App to compile.
However, I keep getting the same compile error, BlynkTimer does not name a type.
My thoughts are the library, I have latest library but notice the BlynkTimer is separate from BlynkSimpleEsp8266.h in a folder called Blynk. Should this mean a separate include statement is required to make the example code work?
Not tried it yet but nobody else seems to have mentioned the compile fault I keep getting with latest libraries.
Thanks Gunner,
I had tried reinstalling the libraries before you suggested it to no avail. However, I thought I would give it another go and this time the compile error had moved further into the code but with a similar ‘type’ error for my timer. This time though it was obvious what was wrong as I was not being stumped at the BlynkTimer timer; declaration. Foolishly I had not complimented the timer.setInterval(1000L, myTimerEvent); statement with the relevant function he he!
Now working fine but much appreciated your response and as usual discussion has helped solve the problem.
