I am new to Blynk, just spend a couple of evenings trying get it up and running. To be able to see some home stuff data so fancy/fast on your mobile phone, really cool!
I am using a Raspbery Pi 3, connecting to it via SSH. When i run my test script manually it is working fine and this is the output (i also see it on my phone so its working) :
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ for Python v0.2.0 (Linux)
1 sec elapsed, sending data to the server...
However when i try to start that script automatically using crontab (sudo crontab -e), i can see in the log file that i am getting the following error:
Traceback (most recent call last):
File "/home/pi/blynk-library-python-master/examples/testnew3.py", line 20, in <module>
File "/usr/local/lib/python2.7/dist-packages/BlynkLib.py", line 224, in __init__
BlynkProtocol.__init__(self, auth, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/BlynkLib.py", line 59, in __init__
self.connect()
File "/usr/local/lib/python2.7/dist-packages/BlynkLib.py", line 236, in connect
raise ValueError('Connection with the Blynk server %s:%d failed' % (self.server, self.port))
ValueError: Connection with the Blynk server blynk-cloud.com:80 failed
This is my crontab code:
@reboot sudo /bin/sleep 5 ; sudo /usr/bin/python /home/pi/blynk-library-python-master/examples/testnew3.py > /home/pi/blynk-library-python-master/examples/log.out 2>&1
And this is my python script itself:
import BlynkLib
import time
BLYNK_AUTH = 'mytoken'
# initialize Blynk
temp = 15
tmr_start_time = time.time()
#print("while true starting up...")
while True:
blynk.run()
t = time.time()
if t - tmr_start_time > 1:
temp = temp + 1
if temp > 25:
temp = 15
print("1 sec elapsed, sending data to the server...")
now = time.ctime(int(time.time()))
# blynk.virtual_write(0, "time:" + str(t))
blynk.virtual_write(0, str(now))
blynk.virtual_write(4, temp)
tmr_start_time += 1
Anyone can help me out here?
Thx!
