hey guys…
i need to measure the heart rate BPM to display on my Blynk.
but the sensor doesn’t seems to be responding according to my finger placement. if i put my finger the sensor wont showing anything, the sensor showing some result only when i try tapping the sensor, and it get random BPM.
i got code from https://github.com/vamsikikkuri/Pulse-Sensor IoT/blob/master/Pulse_Sensor_Final.ino.
code tht i use :
#define pulsePin A0
char auth[] = "";//yourauthtoken
char ssid[] = "Pocophone";//name of your wifi
char pass[] = "12345678";//password of wifi
int rate[10];
unsigned long sampleCounter = 0;
unsigned long lastBeatTime = 0;
unsigned long lastTime = 0, N;
int BPM = 0;
int IBI = 0;
int P = 512;
int T = 512;
int thresh = 510;
int amp = 100;
int Signal;
boolean Pulse = false;
boolean firstBeat = true;
boolean secondBeat = true;
boolean QS = false;
if (QS == true) {
Serial.println("BPM : "+ String(BPM));
Blynk.virtualWrite(V1, BPM);
QS = false;
} else if (millis() >= (lastTime + 2)) {
readPulse();
lastTime = millis();
void readPulse() {
Signal = analogRead(pulsePin);
sampleCounter += 2;
int N = sampleCounter - lastBeatTime;
detectSetHighLow();
if (N > 250) {
if ( (Signal > thresh) && (Pulse == false) && (N > (IBI / 5) * 3) )
pulseDetected();
if (Signal < thresh && Pulse == true) {
Pulse = false;
amp = P - T;
thresh = amp / 2 + T;
P = thresh;
T = thresh;
if (N > 2500) {
thresh = 510;
P = 512;
T = 512;
lastBeatTime = sampleCounter;
firstBeat = true;
secondBeat = true;
void detectSetHighLow() {
if (Signal < thresh && N > (IBI / 5) * 3) {
if (Signal < T) {
T = Signal;
if (Signal > thresh && Signal > P) {
P = Signal;
void pulseDetected() {
Pulse = true;
IBI = sampleCounter - lastBeatTime;
if (firstBeat) {
firstBeat = false;
return;
if (secondBeat) {
secondBeat = false;
for (int i = 0; i <= 9; i++) {
rate[i] = IBI;
word runningTotal = 0;
for (int i = 0; i <= 8; i++) {
rate[i] = rate[i + 1];
runningTotal += rate[i];
rate[9] = IBI;
runningTotal += rate[9];
runningTotal /= 10;
BPM = 60000 / runningTotal;
QS = true;
thank you
PS : sorry if my english bad
