I’m trying to create a timer that will start a motor if it’s not running and stop it at a certain time if it is running.
My problem is, if the motor is already running when the timer starts, it get’s a stop signal then when the timer ends it get’s the normal stop signal. I’m not sure why. The problem is in the “BLYNK_WRITE(V5)” area of my sketch.
I’m using a NodeMCU with Blynk.
#include <OneWire.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <Wire.h>
#define N_DIMMERS 3
#define led_pin D0
bool enableTimer = true; // Defaults to enable timer (button on vPin 3)
// Temp Data Start
#define ONE_WIRE_BUS D7
DeviceAddress insideThermometer;
// Temp Data Stop
int dimmer_pin[] = {14, 5, 15};
// Voltage Sensor Data
float vout = 0.0;
float vin = 0.0;
float R1 = 29980.0; //
float R2 = 7520.0; //
int value = 0;
char auth[] = "**";
char ssid[] = "**";
char pass[] = "**";
char host[] = "ESP-OTA";
// Select your pin with physical button
const int btnPin = D5;
const int Stop = D6;
const int Prime = D6;
WidgetLED led3(V3);
WidgetLED led4(V4);
BLYNK_CONNECTED() {
Blynk.syncAll();
void LedWidget() {
if (digitalRead(btnPin) == HIGH) { // Sets LED widget ON or OFF depending on state of btnpin
led3.on();
led3.off ();
if (digitalRead(Stop) == HIGH) { // Sets LED widget ON or OFF depending on state of btnpin
led4.on();
led4.off ();
void ButtonWidget() {
Blynk.virtualWrite(V20, HIGH);
Blynk.virtualWrite(V20, LOW);
Blynk.virtualWrite(V21, HIGH);
Blynk.virtualWrite(V21, LOW);
if (digitalRead(Prime) == HIGH) { // Sets LED widget ON or OFF depending on state of btnpin
Blynk.virtualWrite(V22, HIGH);
Blynk.virtualWrite(V22, LOW);
void myTimerEvent()
value = analogRead(A0);
vout = (value * 3.253 / 1024); // see text
vin = vout / (R2 / (R1 + R2));
Blynk.virtualWrite(V1, vin);
// Temp Data Start
void myTempEvent()
sensors.requestTemperatures(); // Send the command to get temperatures
printTemperature(insideThermometer); // Use a simple function to print out the data
// Temp Data Stop
pinMode(ONE_WIRE_BUS, INPUT);
pinMode(led_pin, OUTPUT);
digitalWrite(led_pin, LOW);
pinMode(btnPin, OUTPUT);
pinMode(Stop, OUTPUT);
digitalWrite(btnPin, LOW);
digitalWrite(Stop, LOW);
timer.setInterval(100L, LedWidget);
timer.setInterval(100L, ButtonWidget);
// Temp data start
timer.setInterval(1000L, myTempEvent);
Serial.println("Dallas Temperature IC Control Library Demo");
Serial.print("Locating devices...");
sensors.begin();
Serial.print("Found ");
Serial.print(sensors.getDeviceCount(), DEC);
Serial.println(" devices.");
if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
Serial.print("Device 0 Address: ");
printAddress(insideThermometer);
Serial.println();
sensors.setResolution(insideThermometer, 9);
Serial.print("Device 0 Resolution: ");
Serial.print(sensors.getResolution(insideThermometer), DEC);
Serial.println();
// Temp Data Stop
Serial.println("Booting");
WiFi.mode(WIFI_STA);
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
Serial.println("Retrying connection...");
/* switch off led */
digitalWrite(led_pin, HIGH);
/* configure dimmers, and OTA server events */
analogWriteRange(1000);
analogWrite(led_pin, 990);
for (int i = 0; i < N_DIMMERS; i++) {
pinMode(dimmer_pin[i], OUTPUT);
analogWrite(dimmer_pin[i], 50);
ArduinoOTA.setHostname(host);
ArduinoOTA.onStart([]() { // switch off all the PWMs during upgrade
analogWrite(dimmer_pin[i], 0);
analogWrite(led_pin, 0);
ArduinoOTA.onEnd([]() { // do a fancy thing with our board led at end
for (int i = 0; i < 30; i++) {
analogWrite(led_pin, (i * 100) % 1001);
delay(50);
ArduinoOTA.onError([](ota_error_t error) {
(void)error;
ESP.restart();
/* setup the OTA server */
ArduinoOTA.begin();
Serial.println("Ready");
BLYNK_WRITE(V5) {
int setting = param.asInt();
enableTimer = setting;
if ((enableTimer == 1) && (vin < 10)) {
Serial.println("Start x on");
digitalWrite(btnPin, HIGH);
timer.setTimeout(15000L, []() { // 15 seconds
}); // END Timer Function
//stop running
if ((enableTimer == 0) && (vin > 10))
Serial.println("Shutdown x on");
digitalWrite(Stop, HIGH);
timer.setTimeout(2000L, []() { // 2 seconds
//stop running
BLYNK_WRITE(V20) {
digitalWrite(btnPin, param.asInt()); // Sets btnPin HIGH or LOW depending on state of Button Widget.
int value = param.asInt();
if (value == 1) {
//stop running
BLYNK_WRITE(V21) {
digitalWrite(Stop, param.asInt()); // Sets Stop HIGH or LOW depending on state of Button Widget.
int kill = param.asInt();
if (kill == 1) {
//stop running
BLYNK_WRITE(V22) {
digitalWrite(Prime, param.asInt()); // Sets Prime HIGH or LOW depending on state of Button Widget.
int Prime = param.asInt();
if (Prime == 1) {
Serial.println("Prime x on");
//stop running
BLYNK_WRITE(V23) {
BLYNK_WRITE(V24) {
// Temp Data Start
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
// Serial.print(" Temp F: ");
// Serial.println(DallasTemperature::toFahrenheit(tempC)); // Converts tempC to Fahrenheit
Blynk.virtualWrite(V2, DallasTemperature::toFahrenheit(tempC));
Main function. It will request the tempC from the sensors and display on Serial.
void printAddress(DeviceAddress deviceAddress)
for (uint8_t i = 0; i < 8; i++)
if (deviceAddress[i] < 16) Serial.print("0");
Serial.print(deviceAddress[i], HEX);
// Temp Data Stop
ArduinoOTA.handle();
Any help would be appreciated.
Thank you in advance.
