I am making get requests in my program. If the ESP32 is not connected to the Blynk server, everything works fine, but as soon as it connects to Blynk, get requests do not work.
I am working with the ESP32 and Micropython. Below is the code and the errors I am getting.
import machine
import time
import BlynkLib # https://github.com/vshymanskyy/blynk-library-python/blob/master/examples/03_sync_virtual.py
from BlynkTimer import BlynkTimer
import network
import urequests as requests
BLYNK_AUTH = 'VeGkFg63Yi23wrwAUDctKaAjZgUC'
TIEMPO_ESPERAR_CONEXION_WIFI=25
wifi = network.WLAN(network.STA_IF)
wifi.active(True)
wifi.connect("INFINITU242_2.4","CNC917MDE")
tiempoInicialPeriodo = time.time()
while not wifi.isconnected() and time.time()-tiempoInicialPeriodo<TIEMPO_ESPERAR_CONEXION_WIFI:
time.sleep(5)
print('WiFi IP:', wifi.ifconfig()[0])
data = requests.get(url='https://api.open-meteo.com/v1/forecast?latitude=22.28519&longitude=-97.87777¤t=temperature_2m').text
print("Here 1 -OK: ",data)
print("Connecting to Blynk server...")
blynk = BlynkLib.Blynk(BLYNK_AUTH,server="ny3.blynk.cloud")
print("Here 2 -Error: ",data)
`MicroPython v1.20.0 on 2023-04-26; 4MB/OTA module with ESP32
Type "help()" for more information.
>>> %Run -c $EDITOR_CONTENT
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ for Python v1.0.0 (esp32)
WiFi IP: 192.168.1.79
Here 1 -OK: {"latitude":22.25,"longitude":-97.875,"generationtime_ms":0.017762184143066406,"utc_offset_seconds":0,"timezone":"GMT","timezone_abbreviation":"GMT","elevation":21.0,"current_units":{"time":"iso8601","interval":"seconds","temperature_2m":"°C"},"current":{"time":"2025-08-30T19:15","interval":900,"temperature_2m":33.9}}
Connecting to ny3.blynk.cloud:443...
Traceback (most recent call last):
File "<stdin>", line 32, in <module>
File "urequests.py", line 180, in get
File "urequests.py", line 93, in request
OSError: [Errno 12] ENOMEM
Here is the program and output without using Blynk:
import machine
import time
import network
wifi.active(True)
wifi.connect("INFINITUM2426_2.4","CNnC917MDE")
#desplegarMensajeVisual(1)
time.sleep(5)
#if not wifi.isconnected():
#desplegarMensajeVisual(2)
#desplegarMensajeVisual(3)
# CICLO INFINITO EN ESPERA POR EVENTOS
while True:
try:
print("Here 2 -OK: ",data)
time.sleep(5)
except KeyboardInterrupt:
break
wifi.disconnect()
time.sleep(1)
print("WiFi disconnected")
else:
print("WiFi connected. Can't disconnect")
print("Programa terminado")
OUTPUT
Here 1 -OK: {"latitude":22.25,"longitude":-97.875,"generationtime_ms":0.013113021850585938,"utc_offset_seconds":0,"timezone":"GMT","timezone_abbreviation":"GMT","elevation":21.0,"current_units":{"time":"iso8601","interval":"seconds","temperature_2m":"°C"},"current":{"time":"2025-08-31T04:00","interval":900,"temperature_2m":28.5}}
Here 2 -OK: {"latitude":22.25,"longitude":-97.875,"generationtime_ms":0.015020370483398438,"utc_offset_seconds":0,"timezone":"GMT","timezone_abbreviation":"GMT","elevation":21.0,"current_units":{"time":"iso8601","interval":"seconds","temperature_2m":"°C"},"current":{"time":"2025-08-31T04:00","interval":900,"temperature_2m":28.5}}
Here 2 -OK: {"latitude":22.25,"longitude":-97.875,"generationtime_ms":0.021219253540039062,"utc_offset_seconds":0,"timezone":"GMT","timezone_abbreviation":"GMT","elevation":21.0,"current_units":{"time":"iso8601","interval":"seconds","temperature_2m":"°C"},"current":{"time":"2025-08-31T04:00","interval":900,"temperature_2m":28.5}}
Here 2 -OK: {"latitude":22.25,"longitude":-97.875,"generationtime_ms":0.027894973754882812,"utc_offset_seconds":0,"timezone":"GMT","timezone_abbreviation":"GMT","elevation":21.0,"current_units":{"time":"iso8601","interval":"seconds","temperature_2m":"°C"},"current":{"time":"2025-08-31T04:00","interval":900,"temperature_2m":28.5}}
Here 2 -OK: {"latitude":22.25,"longitude":-97.875,"generationtime_ms":0.0152587890625,"utc_offset_seconds":0,"timezone":"GMT","timezone_abbreviation":"GMT","elevation":21.0,"current_units":{"time":"iso8601","interval":"seconds","temperature_2m":"°C"},"current":{"time":"2025-08-31T04:00","interval":900,"temperature_2m":28.5}}
Here 2 -OK: {"latitude":22.25,"longitude":-97.875,"generationtime_ms":0.012278556823730469,"utc_offset_seconds":0,"timezone":"GMT","timezone_abbreviation":"GMT","elevation":21.0,"current_units":{"time":"iso8601","interval":"seconds","temperature_2m":"°C"},"current":{"time":"2025-08-31T04:00","interval":900,"temperature_2m":28.5}}
Here 2 -OK: {"latitude":22.25,"longitude":-97.875,"generationtime_ms":0.02396106719970703,"utc_offset_seconds":0,"timezone":"GMT","timezone_abbreviation":"GMT","elevation":21.0,"current_units":{"time":"iso8601","interval":"seconds","temperature_2m":"°C"},"current":{"time":"2025-08-31T04:00","interval":900,"temperature_2m":28.5}}
File "<stdin>", line 36, in <module>
KeyboardInterrupt:
The output is fine.
