I figured out all steps with my NodeMCU,now i need to solve ip forwarding.
Here is my code:
#include <ESP8266WiFiMulti.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <WiFiClient.h>
#include <ArduinoOTA.h>
#include <WiFiUdp.h>
extern "C" {
#include "user_interface.h"
uint16 readvdd33(void);
ESP8266WebServer server(8266);
const char* serverIndex = "<form method='POST' action='/update' enctype='multipart/form-data'><input type='file' name='update'><input type='submit' value='Update'></form>";
const char* host = "NodeMCU-webupdate";
char auth[] = "xxx";
const int BlueLED = D4;
int ledState = LOW;
long previousMillis = 0;
long interval = 1000;
WidgetTerminal terminal(V20);
ESP8266WiFiMulti wifiMulti;
boolean connectioWasAlive = true;
SimpleTimer upload;
WidgetLCD lcd(V19);
IPAddress myip;
int voltage = readvdd33();
int Led1=D8;
int Led2=D9;
long rssi;
void beep(unsigned char delayms)
analogWrite(14, 20);
delay(delayms);
analogWrite(14, 0);
delay(delayms);
void GetExternalIP()
WiFiClient client;
if (!client.connect("api.ipify.org", 80)) {
Serial.println("Failed to connect with 'api.ipify.org' !");
else {
int timeout = millis() + 5000;
client.print("GET /?format=json HTTP/1.1\r\nHost: api.ipify.org\r\n\r\n");
while (client.available() == 0) {
if (timeout - millis() < 0) {
Serial.println(">>> Client Timeout !");
client.stop();
return;
int size;
while ((size = client.available()) > 0) {
uint8_t* msg = (uint8_t*)malloc(size);
size = client.read(msg, size);
Serial.write(msg, size);
terminal.flush();
terminal.write(msg, size);
terminal.flush();
free(msg);
void DataUpload()
Blynk.virtualWrite(V11, millis() / 3600000); // Uptime Hours
Blynk.virtualWrite(V12, millis() / 60000); // Uptime Minutes
Blynk.virtualWrite(V13,readvdd33());
terminal.flush();
terminal.println(F("--IoT Voltage Monitor--"));
terminal.flush();
void WebUpdate() {
Serial.println("WebUpdate is booting");
terminal.flush();
terminal.println("WebUpdate is booting");
if(WiFi.waitForConnectResult() == WL_CONNECTED){
MDNS.begin(host);
server.on("/", HTTP_GET, [](){
server.sendHeader("Connection", "close");
server.send(200, "text/html", serverIndex);
server.on("/update", HTTP_POST, [](){
server.send(200, "text/plain", (Update.hasError())?"FAIL":"OK");
ESP.restart();
HTTPUpload& upload = server.upload();
if(upload.status == UPLOAD_FILE_START){
Serial.setDebugOutput(true);
WiFiUDP::stopAll();
Serial.printf("Update: %s\n", upload.filename.c_str());
uint32_t maxSketchSpace = (ESP.getFreeSketchSpace() - 0x1000) & 0xFFFFF000;
if(!Update.begin(maxSketchSpace)){
Update.printError(Serial);
} else if(upload.status == UPLOAD_FILE_WRITE){
if(Update.write(upload.buf, upload.currentSize) != upload.currentSize){
} else if(upload.status == UPLOAD_FILE_END){
if(Update.end(true)){ //true to set the size to the current progress
Serial.printf("Update Success: %u\nRebooting...\n", upload.totalSize);
terminal.flush();
Serial.setDebugOutput(false);
yield();
server.begin();
MDNS.addService("http", "tcp", 80);
Serial.printf("Ready! Open http://%s.local:8266 in your browser\n", host);
terminal.println("Ready! Open http:NodeMCU-webupdate:8266 in your browser");
terminal.flush();
Serial.println("WiFi Failed");
terminal.println("WiFi Failed");
terminal.flush();
beep(300);
beep(300);
beep(50);
beep(300);
beep(300);
wifiMulti.addAP("ssidxxx", "passxxx"); //No 1 SSID
wifiMulti.addAP("xxxSSID", "xxxpass"); //No 2 SSID
ArduinoOTA.setHostname("NodeMCU-IoT");
Blynk.config(auth);
Blynk.connect(3333);
ArduinoOTA.setPassword((const char *)"OTAxxxPass");
ArduinoOTA.begin();
pinMode(BlueLED, OUTPUT);
pinMode(V25, OUTPUT);
pinMode(V26, OUTPUT);
unsigned long maxMillis=millis() + 8000;
while ((Blynk.connect() == false) && ( millis() <= maxMillis)) {
myip = WiFi.localIP();
Blynk.notify("NodeMCU Started!");
terminal.println("...Terminal opened...");
terminal.flush();
terminal.println(F("Blynk v" BLYNK_VERSION ));
terminal.println(F("-------------"));
terminal.println(F("---NodeMCU---"));
terminal.println(F("IoT Voltage Monitor"));
terminal.println(F("by elanozturk"));
terminal.flush();
upload.setInterval(30000L, DataUpload);
BLYNK_WRITE(V20)
if (String("Auth") == param.asStr()) {
terminal.flush();
terminal.println(String(auth)) ;
terminal.flush();
else if (String("Ssid") == param.asStr()) {
terminal.flush();
terminal.println(WiFi.SSID()) ;
terminal.flush();
else if (String("Volt") == param.asStr()) {
terminal.flush();
terminal.println(String(voltage));
terminal.flush();
else if (String("Rst") == param.asStr()) {
terminal.flush();
terminal.println(F("IoT Voltage Monitor going to restart..."));
terminal.flush();
ESP.reset();
else if (String("Ip") == param.asStr()) {
terminal.flush();
GetExternalIP();
terminal.flush();
terminal.print("unknown command:");
terminal.write(param.getBuffer(), param.getLength());
terminal.println();
terminal.flush();
terminal.flush();
BLYNK_WRITE(V8) // Wifi strength
int pinData = param.asInt();
if(pinData==1) {
lcd.clear();
lcd.print(0 ,0,"Wifi Strength");
lcd.print(0 ,1,rssi);
lcd.print(0 ,0,"Voltage Monitor");
lcd.print(0 ,1,"by elanozturk");
BLYNK_WRITE(V9) // IP Address
if(pinData==1) {
lcd.clear();
lcd.print(0 ,0,"IP ADDRESS:");
String fullip = String(myip[0]) + "." + myip[1] + "." + myip[2] + "." + myip[3];
lcd.print(0, 1, fullip);
BLYNK_WRITE(V25) //OTA Web Update mode Start
if (pinData == 1)
WebUpdate();
BLYNK_WRITE(V26) //Reset Button
if (pinData == 1)
{ Serial.println("IoT Voltage Monitor going to restart...");
terminal.flush();
terminal.flush();
ESP.reset();
void monitorWiFi()
if (wifiMulti.run() != WL_CONNECTED)
if (connectioWasAlive == true)
connectioWasAlive = false;
Serial.print("Looking for WiFi ");
Serial.print(".");
delay(500);
else if (connectioWasAlive == false)
Serial.printf(" connected to %s\n", WiFi.SSID().c_str());
monitorWiFi();
server.handleClient();
ArduinoOTA.handle();
upload.run();
rssi=WiFi.RSSI();
myip=WiFi.localIP();
unsigned long currentMillis = millis();
if(currentMillis - previousMillis > interval)
if (ledState == LOW)
ledState = HIGH;
ledState = LOW;
digitalWrite(BlueLED, ledState);
