Hi, have a couple Blynk apps working on iOS and communicating well with my hardware. On the iOS app side, trying to set a gradient color on Gauge widget. I read about the functionality in the docs, but not sure how to get the multiple color options on the gauge. All I see is the standard, click on the color selector and it rotates between all the color options. I am looking for the way to select a gradient color option, like the warm one. My goal is to have the Gauge change from Green to Orange then to Red based on the value in the virtual pin. I believe I can accomplish with hardware side code and change the Color attribute on the gauge via code, but the color gradient sounds much easier, and less work on the Arduino board.
Here’s the wording from the Docs I am referring to: Color gradient
When you choose gradient, it affects the color of widget elements based on invoming values. For example: You set Gauge Widget with Min and Max parameters of 0-100, and choose green-yellow-red gradient. When hardware sends: - 10 , Gauge will change it’s color to green color - 50 will change Gauge to yellow color - 80 will change Gauge to red color
There are 2 types of gradients you can choose from: - Warm: Green - Orange - Red; - Cold: Green - Blue - Violet;
I suspect I am overlooking a simple way to get to the color selector, but after reading, searching, and exploring options I’m resorting to asking this group for help. Thank you…
I do not have an android to try it on. The Blynk docs do mention the limitation of Android only for the Eventor functionality, but I do not see any Android restrictions for this function. Thanks for the idea.
Any other thoughts on accessing color gradient for this on iOS? I feel like I’m missing something. Or, the docs need updated to clarify it’s not really available?
A popular use for Blynk (and IoT in general) is in community air quality monitoring. Simply hook up an inexpensive sensor to a Node or WeMos and off you go! But many intended users want to see the results in terms of AQI (Air Quality Index) which is typically expressed as a continuum of colors (Green, Orange, Red, Purple, etc.) around a circle. It would seem that Blynk GAUGE (with proper color gradient) would fit the bill, but apparently ALAS not available on IoS!! Can Blynk please let us know when we can expect such functionality? Thanks.
Support for gradient colors in Gauge will be added in next Blynk iOS app update.
Note that these are just few predefined gradient colors. Fo fine color control, you’ll have to do this manually anyway (using setProperty method in your sketch)
