Gas sensor With GSM & Arduino with blynk
Hello everyone, I am new to this community forum. I am making a project
with Arduino Uno , Gsm Module SIM800 , MQ2 Gas Sensor With 2 leds With BLYNK USB serial connection. I want to run AT commands (USES SERIAL MONITOR) for GSM to call a phone Number when MQ2 detects Any gas in environment. But I want to know I am using blynk code in it. So i will be able to run AT commands For gsm Or not with the blynk code ??? And please tell me if there are any errors, also i am send a sensors data from analog pin A5 to Blynk app so please check my code and tell me , i have tested the project partially and i am able to connect to blynk server.
#define BLYNK_PRINT SwSerial
SoftwareSerial SwSerial(3, 4);
char auth[] = "9af4b603a79f4b1bae0aedd050490f62";
int redled = 8;
int greenled = 9;
int buzzer = 10;
int streetled = 11;
int streetred = 12;
int smokeA0 = A5;
int sensorThres = 400; //Change
void TweetEmailAndNotification()
int analogSensor = analogRead(smokeA0);
if (analogSensor > sensorThres)
Blynk.tweet("DANGER! GAS LEAKAGE DETECTED, location link- maps.app.goo.gl/mzHCg");
Blynk.email("GAS LEAKAGE DETECTED!!", "GAS LEAKAGE HAS BEEN DETECTED!! Location -maps.app.goo.gl/mzHCg");
Blynk.notify("GAS LEAKAGE!!{FLAME & GAS DETECTION SYSTEM} HAS DETECTED GAS LEAKAGE ALERT!");
void sensorDataSend()
int sensorValue = analogRead(A5);         // reading sensor from analog pin
  Blynk.virtualWrite(V1, sensorValue);  // sending sensor value to Blynk app
pinMode(redled, OUTPUT);
pinMode(greenled, OUTPUT);
pinMode(buzzer, OUTPUT);
pinMode(streetled, OUTPUT);
pinMode(streetred, OUTPUT);
pinMode(smokeA0, INPUT);
timer.setInterval(1000L, sensorDataSend);
SwSerial.begin(9600);
Blynk.tweet("MICROCONTROLLER STARTED :)");
delay(100);
digitalWrite(redled, HIGH);
digitalWrite(greenled, LOW);
digitalWrite(streetled, HIGH);
digitalWrite(streetred, HIGH);
Serial.println((char)26);// ASCII code of CTRL+Z for saying the end of sms to the module
delay(100);
tone(buzzer, 1000,500);
Serial.println("ATDxxxxxxxx;");
digitalWrite(redled, LOW);
digitalWrite(greenled, HIGH);
noTone(buzzer);
digitalWrite(streetred, LOW);
The purpose of using BlynkTimer is to NOT have so much code in your void loop() trying to run thousands of times a second.
http://help.blynk.cc/getting-started-library-auth-token-code-examples/blynk-basics/keep-your-void-loop-clean
Since your GSM is being used for the Blynk connection, it will not be easy for it to also call any phone numbers. Perhaps not impossible, but you would have to manually manage the Blynk connections (disconnect, call out, reconnect, etc) in your code.
