Alright, I don’t have a way to output debug information since I am using the USB connection variant, however I started a new sketch and Blynk is working as expected. So I am assuming it must be my code then.
Here is the debug sketch that is working perfectly fine:
char auth[] = "nah";
WidgetTerminal terminal(V0);
int stepper = 0;
BLYNK_WRITE(V1)
stepper = param.asInt();
terminal.println(param.asInt());
terminal.flush();
BLYNK_WRITE(V2)
terminal.println(stepper);
terminal.flush();
BLYNK_CONNECTED()
Blynk.syncAll();
digitalWrite(2, HIGH);
delay(500);
digitalWrite(2, LOW);
pinMode(2, OUTPUT);
Blynk.begin(Serial, auth);
Now, here is my actual code that executes the Blank Connected method over and over again:
// HydroCab - June 2018
#include <TimeLib.h>
#include <WidgetRTC.h>
String hostname = "nah.nah.com";
BlynkTimer timerSystem;
WidgetRTC rtc;
WidgetTerminal terminal(V13);
// Digital Control Pins
int hydroPump = 2;
int growingLight = 3;
int airPump = 4;
int fans = 5;
int supplyPump = 8;
// Analog Sensor Pins
int dhtInternal = A0;
int dhtExternal = A1;
int waterLevel = A2;
// Sensor Thresholds
int waterLow = 0;
int waterHigh = 0;
int internalTempHigh = 0;
int externalTempHigh = 0;
int internalHumHigh = 0;
int externalHumHigh = 0;
// Timers
int lampTimer = 1;
int statsTimer = 2;
int pumpTimer = 3;
long lampTimerInterval = 5000; // 5 seconds
long statsTimerInterval = 5000; // 5 seconds
long pumpTimerInterval = 500; // 0.5 seconds
// Lamp Time
int startHour = 0;
int stopHour = 0;
// Pump Timer
unsigned long onTime = 0;
unsigned long offTime = 0;
unsigned long interval = onTime;
boolean pumpState = false;
// Pin Modes
pinMode(hydroPump, OUTPUT);
pinMode(airPump, OUTPUT);
pinMode(growingLight, OUTPUT);
pinMode(fans, OUTPUT);
pinMode(supplyPump, OUTPUT);
pinMode(LED_BUILTIN, OUTPUT);
pinMode(dhtInternal, INPUT);
pinMode(dhtExternal, INPUT);
pinMode(waterLevel, INPUT);
// Timers
statsTimer = timerSystem.setInterval(statsTimerInterval, statsRoutine);
// Notify on boot
terminalOutput("System fired up.");
void pumpRoutine()
digitalWrite(hydroPump, pumpState);
unsigned long currentMillis = millis();
if ((unsigned long)(currentMillis - previousMillis) >= interval)
if (pumpState)
interval = offTime;
interval = onTime;
pumpState = !(pumpState);
terminalOutput("Pump state changed.");
void lampRoutine()
int h = hour();
if ((h >= startHour) && (h < stopHour))
if (digitalRead(growingLight) == LOW)
digitalWrite(growingLight, HIGH);
terminalOutput("Starting growing light.");
if (digitalRead(growingLight) == HIGH)
digitalWrite(growingLight, LOW);
terminalOutput("Stopping growing light.");
void statsRoutine()
// replace random figures with actual sensor values
// Internal Humidity
Blynk.virtualWrite(V0, random(0, 100));
// External Humidity
Blynk.virtualWrite(V1, random(0, 100));
// Internal Temperature
Blynk.virtualWrite(V2, random(0, 100));
// External Temperature
Blynk.virtualWrite(V3, random(0, 100));
// Water Level
Blynk.virtualWrite(V4, random(0, 100));
String getDateTime()
String currentDate = String(day()) + "/" + month() + "/" + year();
return String(currentDate + " - " + currentTime);
void terminalOutput(String value)
terminal.println("");
terminal.print(String(getDateTime() + ": "));
terminal.print(value);
terminal.flush();
// Hydro Pump Control
BLYNK_WRITE(V6)
int pinValue = param.asInt();
if (pinValue == 1)
pumpTimer = timerSystem.setInterval(pumpTimerInterval, pumpRoutine);
timerSystem.disable(pumpTimer);
pumpState = false;
previousMillis = 0;
digitalWrite(hydroPump, LOW);
// Air Pump Control
BLYNK_WRITE(V7)
if (pinValue == 1)
digitalWrite(airPump, HIGH);
terminalOutput("Air pump started.");
digitalWrite(airPump, LOW);
terminalOutput("Air pump stopped.");
// Lamp Control
BLYNK_WRITE(V8)
if (pinValue == 1)
lampTimer = timerSystem.setInterval(lampTimerInterval, lampRoutine);
timerSystem.disable(lampTimer);
// Fan Control
BLYNK_WRITE(V9)
if (pinValue == 1)
digitalWrite(fans, HIGH);
terminalOutput("Fans started.");
digitalWrite(fans, LOW);
terminalOutput("Fans stopped.");
// Start Stop Time Control
BLYNK_WRITE(V10)
TimeInputParam t(param);
if (t.hasStartTime())
startHour = t.getStartHour();
if (t.hasStopTime())
stopHour = t.getStopHour();
// Supply Pump Control
BLYNK_WRITE(V11)
if (pinValue == 1)
digitalWrite(supplyPump, HIGH);
terminalOutput("Supply pump started.");
digitalWrite(supplyPump, LOW);
terminalOutput("Supply pump stopped.");
// Pump On Time Stepper
BLYNK_WRITE(V14)
onTime = param.asInt() * 60000;
terminalOutput(String(onTime / 60000));
// Pump Off Time Stepper
BLYNK_WRITE(V15)
offTime = param.asInt() * 60000;
terminalOutput(String(offTime / 60000));
BLYNK_CONNECTED()
rtc.begin();
Blynk.syncAll();
terminalOutput("Blynk connected.");
timerSystem.run();
Can you see anything obviously wrong with my code?
Cheers,
Dan
